Less Maintenance With EIFS Or Painted Wood / Siding, Etc. Ceilings, Soffits
Old 05-17-2008, 07:18 PM   #1
plazaman's Avatar
Having a discussion with some about Less Maintenance with EIFS or Painted Wood / siding, etc. ceilings, soffits .
What do you think? Shouldn’t it be the same since EIFS is technically textured paint? VS a Painted Surface for example, exterior trim, soffits, ceilings etc? I mean, they are both painted surfaces correct? Should normal pressure washing every year keep them looking clean? This person claims with an EIFS finish, you don’t have to paint as much? I’m not disagreeing 100% but like to know what you guys think.
Systems like dryvit, decoplast, STO, etc...
Rich
plazaman is offline
Old 05-17-2008, 07:29 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Less Maintenance With EIFS Or Painted Wood / Siding, Etc. Ceilings, Soffits
Durock Allfacing use to promote their EIFS as self-cleaning...
I build several homes over a 10 year period with their product...I don't know if I would have called them self cleaning, but no maintenance was ever required on any of them such as needing paint, the color was integrated into the mix.
Chris
Chris Johnson is online now
Old 05-17-2008, 07:38 PM   #3
plazaman's Avatar
i dont know about the self cleaning, but i seen mold/algae on eifs before. So your saying EIFS will have a longer color retention time than a properly prepped surface? Wont fade or discolor?
plazaman is offline
Old 05-17-2008, 07:56 PM   #4
I'm a Mac
From what I saw, including my own house. now keep in mind this work was completed a little over an hour north of Toronto, ON. so UV was not as bad as what I have here in California, where I have seen major fading, then again out here I only see 3 part stucco, no EIFS...insurance companies till aren't liking it.
Chris
Old 05-17-2008, 08:59 PM   #5
plazaman's Avatar
House is Brick face with a wood trim , wood ceiling, house peak with t11, and few other others. client want something with little to none maintenace.
But what is the difference between EIFS finish vs a paint job? isnt the same stuff except its textures?
plazaman is offline
Old 05-17-2008, 09:43 PM   #6
I'm a Mac
EIFS - Exterior Insulated Finish System
It's not just the surface, it's the whole system
Comprised of Expanded Polystyrene (NOT Extruded) this increases the exterior walls insulation value
Basecoat of cementious material and fibermesh
Finish Coat
Between basecoat and finish coat you may need to apply (paint) an acrylic coating depending on the thicknes/grain of the finish material
Google a web site for EIFS and get all the info you need...it's more than just paint
Chris
hanging certainteed cement siding PROJECT MAN Windows, Siding and Doors 46 09-27-2010 10:46 PM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
Are PA siding contractors on crack or is me? Royal-T Windows, Siding and Doors 12 02-10-2008 09:14 AM
unique siding job - HELP tool junkie Windows, Siding and Doors 28 02-01-2008 12:09 AM
9 foot ceilings or 8 foot ceilings with treys? williefb General Discussion 1 02-11-2007 01:29 PM
