Trade: Painter
Lead Tester
The house was built in 1963 and need to find out if theres lead involved? Whats the best way and is there a cheap lead tester out there?
#2 | |
...jammin
Trade: Rock Disciple
Re: Lead Tester
You local Paint Store will have one or two decent testing kits
Signature Quote Quote:
Trade: Painter
Re: Lead Tester
Called Sherwin last night and they said they didn't have anything and to try Home Depot. ( I think she was a new girl) Didn't sound that bright.
Trade: Home Improvement
Re: Lead Tester
I actually just saw a special report on those lead paint test kits and the lead toy test kits and basically the conclusion they came up with when sending known samples to various labs and also trying out the on the spot color change type the results were very poor. You would actually have a better chance of not hitting another car or person driving blindfolded at 60mph in NYC during rush hour than gettin an actual reliable result from any of those testers. And to make it even worse every single coat of paint or primer on top of the coat in question lowers the probability of getting acurate results like 20%
Re: Lead Tester
The whole lead paint thing can be expensive to deal with.If it's a job you've contracted and it's either rental property or there's a child under a certain age in the house,than, some states require a formal test before and after completion of the project. Here you have to be certified to even touch the stuff. So,if you think there is lead,the liability will rest on you. But you probably already knew that. An old painter might have a way to tell with a couple scratches through to the top coats. |
#6 | ||
...jammin
Re: Lead TesterQuote:
cripes...she must have that wrong ...or I'd seriously consider using another shop...that's like not having 5in1 tools
| What Internet lead services should do to corner the market | Mike Finley | Business | 45 | 03-26-2010 09:17 PM |
| lead counter flashing | stanelystoney | Masonry | 4 | 10-18-2007 08:07 PM |
| can anyone recommend a good digital XRF handheld lead tester? | jordanski | Painting & Finish Work | 6 | 04-27-2007 07:58 PM |
| encapsulating lead paint | lornmastro | Painting & Finish Work | 17 | 10-03-2006 09:50 PM |
