Trade: painting contractor
Lead Paint Issue
I am bidding on an exterior where the HO says all of the existing paint is lead (it has not been painted for many years). I have not been certified for lead paint removal, however the guy who has been working for me has.
I want to know: 1. Have any of you done this type of exterior work? 2. How did you handle it? 3. Did you charge extra due to the lead paint issue? My idea is to pressure wash, oil prime to seal the lead paint, wet sand/scrape any lose paint, spot prime again, and then paint final coat. BTW, the exterior surface is`wood. If we cover the ground below, and then wrap everything up and dispose of properly, will I have done everything that I should do to protect us and the environment? Of course we would use respirators and gloves. |
Re: Lead Paint Issue
If the guy working for you has been certified he should know the routine!
Try this link: http://www.envcap.org/statetools/lead/lead.html It will link you to your state requirements.
https://www.facebook.com/pages/John-...94183374011504 |
#3 | |
...jammin
Trade: Rock Disciple
It varies by state, but in any state I've worked in or know about, you can't charge for it unless you are certified
Signature Quote Quote:
#4 | |
Hudson Valley
Trade: Restorative Painting
Re: Lead Paint IssueQuote:
2. By following all guidelines. 3. Charge for the work involved, check with your insurance company that you are covered. Do not use a pressure washer, the containment issues involved are impossible to handle, and it will also damage the substrate. Location will determine preparation process, anywhere close to a school, or public area sub to an experienced, specialized company and stick to applying finish coats.
www.blueskiesrestorations.com There's some top class people on this forum,........and then there's me...Touching cloth. |
REGAL PAINTING
massachusettes: no dry scrape, chips doubble bagged and brought to the dump. epa and dep approved.
what about Blastox
do you have to bag it
I have decided to let this one go. Leave it to the guys who are experienced. My guy who said he was certified for lead paint removal is no longer with me, and I don't need the headache. Thank you for helping me make this decision.
It's really no big deal - just staple your tarps to the lowest piece of wood. Scrape, if you sand - use a hepa vaccum cleaner attached to your sander to suck up the dust. I put a bag in my vaccum - and when I dispose of chips from tarps - I'll open the top of the 'shop' vac and slide the chips into there temporarily - and then whent that's filled, bag it - double bag it - throw it away. You can do a 'softwash' afterwards of the home that is only for killing mildew - use no pressure, just applying chems and rinsing.
Hudson Valley
| What Internet lead services should do to corner the market | Mike Finley | Business | 45 | 03-26-2010 09:17 PM |
| Lead paint | Robie | Painting & Finish Work | 3 | 06-30-2006 08:54 PM |
| Oil Based Paint leaving wrinkly finish on doors | dwbrooks | Painting & Finish Work | 8 | 11-09-2005 11:29 PM |
| Roof paint | Teetorbilt | Roofing | 3 | 05-07-2004 05:47 PM |
