Latex Paint Wont Stick To Latex Primer
Old 05-07-2009, 09:38 PM   #1
dougfra's Avatar
Trade: paint
primed latex painted wall with valspar latex primer waited tell next day and tried to top coat with valspar After three or four passes with roller, its pulling the paint off. I tried light coats heavy coats same result any help
dougfra is offline
Old 05-07-2009, 10:18 PM   #2
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
Re: Latex Paint Wont Stick To Latex Primer
That paint is garbage, see if it were any good a rep could come out and look at the problem but being that there is no reps around you call the 1-800 and good luck.
Mr. Mike is offline
Old 05-07-2009, 10:20 PM   #3
Organic Painter
Mr. Mike's Avatar
You primed the wall, and your painting it now but the paint is pulling the primer off?
Or:
You primed the wall and then put one coat of finish on it and now a second coat of finish is pulling the first finish coat off leaving the primer in tact on the wall?
Please explain...
Mr. Mike is offline
Old 05-07-2009, 10:25 PM   #4
native floridian
jfranklin's Avatar
Trade: Aluminum Contractor & Painting Contractor
you can do it Lowes can help, oh sorry thats Home Depot
Screen Room, Pool Enclosure specialist
jfranklin is offline
Old 05-08-2009, 12:26 AM   #5
sparehair's Avatar
Trade: Painting, flooring
I did one job with customer supplied valspar paint. I wouldn't call it complete junk but 35$ for kilz grade oil primer is reedeeculous.
The other thing I noticed was there was a long tacky period with the paint. That slow cure tendancy is probably what's getting you. Crank all the heaters in there and cook it for a day or two and then try.
sparehair is offline
Old 05-08-2009, 01:02 AM   #6
A bit abrasive.
WisePainter's Avatar
So I read the title to this here thread, and sure enough the author has but 1 lonely post here at CT...
My advice: Hire a real painter to do it.
WisePainter is offline
The Following User Says Thank You to WisePainter For This Useful Post:
jfranklin (05-08-2009)
Old 05-08-2009, 04:47 AM   #7
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
valspar right there is most likely the problem
chris n is offline
Paint or stain on hardi plank? Jer Painting & Finish Work 25 12-24-2009 01:10 PM
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 26 03-06-2009 03:14 PM
Best Primer & Paint for porch railings ? gtmeade Painting & Finish Work 7 05-22-2008 10:23 AM
Oil or Latex Primer corky Painting & Finish Work 4 04-14-2008 07:21 PM
best way to tell if the wall has oil or latex paint?? Zeebo Painting & Finish Work 7 11-10-2005 07:03 PM
