Trade: carpenter
Latex Over Varnish
Hi all. Need some help here. We have existing stairs finished with either varnish or varathane. Need to paint the risers and stringers only with a latex.
My painter wants to use an oil base primer. Customer will not allow this due to fumes. So I need to know what primer to use over the varnish. Painter will of course sand, ready for the primer. Thanks in advance, Kato. |
Trade: no
Re: Latex Over Varnish
Dear Sir, I am sorrry i am a new one! I just learn from you.
Master-Pro-Plus
Trade: Master Plumber/Pipefitter,General Contractor, Plus
You can use a paint deglosser then you can use a Kilz 123 waterbase primer/sealer if you like.
| The Following User Says Thank You to GregC For This Useful Post: | katoman (01-25-2010) |
#4 | |
paper hanger,painter
Re: Latex Over VarnishQuote:
![]() ![]() KIlz would be absolutly the LAST primer to use, it is crap. Use any bonding primer such as BM Fresh Start,Zinnser's bullseye 123, etc You did notice this painting advise about the Kilz came from a plumber, that should tell you something. Last edited by chris n; 01-26-2010 at 06:10 AM. |
Trade: Builder
I was told a long time ago that; "shellac sticks to anything, and everything sticks to shellac". So I would use Bin primer (it's shellac). I'm willing to bet there are exceptions, but I think it would work in your situation.
#6 | |
Master-Pro-Plus
![]() Tell me Chris can you fit or weld pipe? I doubt it, so stick to the tough job of paper hanging. .. oh BTW Chris, there is a spell checker here |
Trade: Historic Restorations
sand to remove gloss...wipe clean...prime with ICI Gripper ...let the primer dry aleast 8 hrs...top coat with premium latex..good to go
Trade: painting
try the odorless oil primer you'll get high but wont know what hit you
Well if the customer doesn't want your painter to use oil base products cause of the smell I would not guaranty the latex will hold up long term, I would use Lacquer thinner wipe down the risers then use the deglosser then use a oil undercoater then your Latex, But I still would tell your customer that they could see the paint fail over time. Good luck.
Master-Pro-Plus
Frankawitz, This is a very good advise. Try to convince your customer that the correct way should last longer. Pay now or pay later.
Trade: carpenter
Thanks for all the replys.
Talked to my painter today. He says he'll sand it down real good and use the shelac based primer. Should be ok. Customer will not allow oil. I agree it would be the best, but it's her house. |
#12 | |
Just wait till the customer gets a good whiff of the Bin, the oil based primer would be perfume compared to that.
Trade: Builder
Yeah, Bin stinks to high heaven, don't use your prize brush either. Buy a sacrifice brush, or gallons of denatured alcohol.
Trade: siding
now for some reason i like the smell of shelac
Tom |
Trade: Painting & Remodeling
SW bonding primer would work fine in latex over scuffed surface. It sticks to glass!
Trade: painting
I should of told you before to use stix(58$ per gal) but i forgot.
I tried it last year it does not come off anything in fact I still have some on my elbow. it smells odd and its pricey but it amazed me how well it stuck to pvc. oh and your bush will be a new duster as well. |
I agree with the one comment, Kilz latex is garbage. I have had really good luck with bin 123 in the past. Also if the home owner is worried about fumes I'd stay away from anything shellac based. Also I find the shellac bin has a tendency to spray, a lot. So if you do use it make sure to overkill on masking off. Good luck man, its sounds like a fun job.
#18 |
I used Kilz over water stains and the stain came coming back. I agree, kilz is crap.
#19 | |
#20 |
Greg as for getting the Customer to understand that would be up to you and how convincing you are. If you can explain to the customer then there should be no problem selling them on that product. You need to understand what the Customer wants Cheap price or Quality job? so if they are middle of the road put that facts on the table and leave the ball in their court. Don't make this dissension for them.
| Stripping latex from cedar wood deck | cascapi | Painting & Finish Work Picture Post | 1 | 10-16-2009 09:53 PM |
| latex paint wont stick to latex primer | dougfra | Painting & Finish Work | 6 | 05-08-2009 04:47 AM |
| Latex over Oil base paint is peeling | iceman61 | Painting & Finish Work | 19 | 10-16-2008 12:44 AM |
| latex semi gloss over oil semi gloss - can it be done? | Zeebo | Painting & Finish Work | 13 | 09-05-2007 06:38 PM |
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
