Latex Over Metal Primer
Old 03-04-2008, 04:00 AM   #1
d-rez's Avatar
Trade: general contractor
I do a lot of exposed welded steel on my projects. I always use a Rustoleum metal type primer(rust/red). I usually paint it a bronze to match the windows, but Rustoleum's bronze is much lighter than the window bronze. Is it okay to paint the top coats in a regular latex or should I have a metal paint mixed to my desired bronze color? Thanks, Chris
d-rez is offline
Old 03-04-2008, 09:08 AM   #2
All ahead flank
Bill in VaBeach's Avatar
Trade: Kitchen and Bath Remodeling, Home Improvement
Re: Latex Over Metal Primer
D-REZ,
Recommend you stick with the metal paint instead of latex. Latex will adhere to the primer with no problems, but the metal paint contains additional rust inhibitors, and over the "red lead" is a predictable combination as you know from doing this routinely. If you are unable to have it mixed for you, try Mixol to darken up the bronze.
Bill in VaBeach is offline
Old 03-04-2008, 09:18 AM   #3
Jonesey's Avatar
Trade: Painting and Finishing
Look at SW's All Surface Enamel. Good stuff, and it adheres well to both metal and primer. Price point is decent, and your local SW shop can tint to any color. The alkyd is what we use on window projects.
Steve Jones
steve@jonespaintingonline.com
Jones Painting Feel the difference service makes
Jonesey is offline
latex semi gloss over oil semi gloss - can it be done? Zeebo Painting & Finish Work 13 09-05-2007 06:38 PM
best exterior latex primer? toddcla2002 Painting & Finish Work 18 11-05-2006 08:03 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 05:35 PM
