Laquering Jambs And Casing
Old 11-06-2009, 10:37 AM   #1
aikenback's Avatar
Trade: all Carpentry, (framing mainly)
Hi everyone, I am on a job where the finisher and his partner did both the finishing and the laquering. Several months after they finished the laquer it has cracked at al the joints between the casing and the jambs as well as the doorstops. I know they caulked the joints because i saw them do it. However I wonder what the problem was. Was thelaquer wrong?, was the caulking not dry enough?, and have any of you seen this before?, I'm just glad I'm not resposible for this trade this time! Any ideas?
aikenback is offline
Old 11-06-2009, 10:27 PM   #2
Metro M & L's Avatar
Trade: Painting & Flooring
Re: Laquering Jambs And Casing
I don't do a lot of lacquer work. The house has probably started to breath a little bit with the change in weather. My guess is the caulk is expanding and contracting as it should but the lacquer is not designed to do that. I don't think I would caulk a stain grade job. The lacquer is just not made to flex and move on a joint like that.
"Yeah... It's worthy of a sig quote."
Metro M & L is offline
Old 11-06-2009, 11:04 PM   #3
Megabass's Avatar
Trade: Painter
What M & L said to a capital T.
Megabass is offline
Old 11-07-2009, 04:32 AM   #4
aikenback's Avatar
I failed to mention that the laquer was solid white over mdf seems to be the way around here. One would think a high gloss latex (flexible) paint would be a better choice. I'm not a painter, but I wonder why the white laquer? Just curious.
Old 11-07-2009, 10:22 AM   #5
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
fast drying time. really fast
go dart is offline
Old 11-07-2009, 11:21 AM   #6
New York City
eastend's Avatar
Trade: historic woodwork restorations
lacquer is a much harder, more brittle finish than say, varnish.It won't give or flex as much, so it could crack much more readily with any movement of the wood
eastend is offline
Old 11-19-2009, 07:28 AM   #7
Rcon's Avatar
Trade: wood finishing
Lacquer gives a far superior looking finish than latex when done properly. I would never caulk anything I was lacquering though. Have you ever seen a factory made cabinet caulked?
Lacquer is flexible, but only as flexible as wood, since it is made of cellulose. It will not flex with the settling/movement of a house, thus it is bad practice to caulk under lacquer. However, even a latex paint will crack at the caulk lines as a house settles - nature of the beast.
Rcon is offline
Domino casing mitres CarpenterMatt Finish Carpentry 20 03-07-2009 08:40 PM
Jambs and Drywall UKframer Finish Carpentry 29 03-01-2008 02:18 PM
Getting laminate under door casing and jambs Blackhawk Flooring 6 01-02-2008 04:14 PM
Assembling casing before triming a door WNYcarpenter Finish Carpentry 15 03-28-2007 09:38 PM
Casing on pre primed window jambs icfbunt Finish Carpentry 10 11-13-2006 09:30 PM
