Ladders
Old 07-01-2006, 07:16 AM   #1
lunaassoc's Avatar
Trade: Painting contractor
Send a message via AIM to lunaassoc Send a message via Yahoo to lunaassoc
Ladders
Can anyone tell me what is the best way to setup on a stair case when paint high walls? Also, I am bidding on a parking garage that requires that stair case leading to roof access be painted need to paint underside of stairs on each floor any suggestion on a good ladder or small scaffolding.
Dave from Big D
lunaassoc is offline
Old 07-01-2006, 07:28 AM   #2
bigchaz's Avatar
Trade: Wood Restoration/Refinishing
Re: Ladders
little giant is a pain in the arse to lug around and adjust but ive used it on stairs with good results
kinda pricey though too
bigchaz is offline
Old 07-01-2006, 08:29 AM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Ladders
I don't know if it would work in your situation
I'm mostly res. repaints and the Pivot Tool helps me out all the time on stairs
Def two thumbs up
Signature Quote
slickshift is offline
Old 07-01-2006, 08:31 AM   #4
lunaassoc's Avatar
Re: Ladders
Def two thumbs up
Where did you get this tool?
Dave from Big D
Old 07-01-2006, 08:40 AM   #5
...jammin
slickshift's Avatar
Re: Ladders
Your local paint shop should have them
Maybe even a tool shop
I think it may even have a Sherwin Williams stock # so they should have it
Really, I used this thing 3 out of 5 days last week
Ladder prop for uneven ground outside, roller tray holder on a 30 ft. ext ladder (it's also a "shelf"), and a "step" for ladders on stairs on an inside cathedral ceiling
That's just last week
Signature Quote
Old 07-01-2006, 09:22 AM   #6
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Ladders
We use a 5-way combination ladder for stairwells. Works very well.
ProWallGuy is offline
Old 07-01-2006, 01:00 PM   #7
KellyPainting's Avatar
Trade: Painting Contractor
Re: Ladders
The other way is to put either a step or sm. extention ladder on one of the stairs twards the bottom of the staircase and lean it against the bottom wall ( when you are walking down the stairs look up and see the wall directly in front of you straight up that connects to the ceiling in the room below) I'll try to attach a drawing. Well you put a plank from the stairs to the step or extention, make sure to put pads on extention so you don't damage the wall.
KellyPainting is offline
Old 07-02-2006, 10:51 PM   #8
Richie-C's Avatar
Re: Ladders
For stairs, I swear by my little giant.
Richie-C
Richie-C is offline
Old 07-03-2006, 04:14 PM   #9
phdptg's Avatar
Re: Ladders
We have this 5 way ladder as well as the Pivot tool. The 5 way ladder is a lot easier to use & 1 less piece of equipment to haul around.
phdptg is offline
Old 07-03-2006, 05:22 PM   #10
painterman's Avatar
Trade: Historic Restorations
Re: Ladders
For me I love my ladder levelers.Work great for stairs and uneven ground.Found them on Ebay for $50.00 a pair.
Stan
painterman is offline
Need Ladders and Sprayers welovepainting Contractor Swap 1 08-21-2007 10:09 PM
Picks and Ladders ARCS Health & Safety 0 12-30-2006 11:35 PM
Ladders joasis General Discussion 15 09-19-2006 09:08 PM
Buying used ladders KellyPainting Painting & Finish Work 2 06-11-2006 03:18 PM
Folding/Telescoping Ladders thw420 Tools & Equipment 3 12-11-2004 12:26 AM
