Old 07-24-2006, 04:37 PM   #1
Trade: Painting / Decorative Concrete
Question Lacquer Thinner or Naphtha
New construction... When spraying new wood doors with oil base can you use Lacquer or Naphtha to increase drying time. We add Lacquer when brushing trim to increase drying, but never sprayed with it. Can you? what's the difference between them? Thanks!!
Guardi Pro is offline   Reply With Quote
Old 07-24-2006, 05:57 PM   #2
Jonesey's Avatar
Trade: Painting and Finishing
Shouldn't add either, period. It will shorten the lifespan of the finish. What works well and won't harm the finish is artist's quality Cobalt drier, or Japan Drier. I cut my dry time in half with artist's quality Japan drier. Only takes about two ounces to a five. Paint store Japan drier isn't as strong, and tends to tint the finish very little to pink. It's not noticable, but it does tint it.
Should use Turpentine to thin oil, it burns off faster, and cleaner than mineral spirits. Just smells really, really bad.
Steve Jones
steve@jonespaintingonline.com
Jones Painting Feel the difference service makes
Jonesey is offline   Reply With Quote
Old 07-24-2006, 08:10 PM   #3
Trade: Paint and wallpaper
Well here's a vote for adding Naptha or Lacquer thinner. Just mix up a small test batch in advance to make sure its compatible. Your oil finishes already have solvent in them, adding solvents that evaporate quicker should just make it dry faster. As with any product, adding solvent usually means you'll be applying a thinner coat. But it shouldn't be too hard to tell how many coats will get you an acceptable finish. We always used Naptha, but have fun experimenting.
If anything Japan Drier shortens the lifspan of the finish because Japan drier causes the dried finish to be more brittle.
phinsher is offline   Reply With Quote
Old 07-27-2006, 10:43 PM   #4
My custom title
Brushslingers's Avatar
Down with oil!!
Really, both are correct however, for spraying doors I wouldn't cut down with anything more than spirts, I like my equipment too much to run Japan drier or Naptha though them. Drier works fanTASIc with a cup gun however... <hinthint>.
Brushslingers is offline   Reply With Quote
Old 07-27-2006, 10:56 PM   #5
Teetorbilt's Avatar
Jonesey, I'm starting to like you. I'm old school too. Turpentine smells great if you grew up with it. I think that Latex smells like old socks.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Has anyone ever heard of using lacquer as a primer?? Dorman Painting Painting & Finish Work 18 10-11-2009 09:38 PM
I hate lacquer DeanV Painting & Finish Work 3 02-01-2007 09:56 PM
Tips on applying lacquer to a garage door Zeebo Painting & Finish Work 10 09-14-2006 09:55 PM
Ok to Polyurethane over old lacquer? Steve Richards Painting & Finish Work 11 03-18-2006 10:59 AM
how do i coat with lacquer after painting? manny Painting & Finish Work 4 02-27-2006 11:16 PM
