"Lacquer-based Varnish" ?
Old 08-24-2007, 07:05 AM   #1
back@it's Avatar
Trade: painting wallcovering and drywall repair
Quoting a job where this is speced, I am not familiar with it. Anybody know what SW or BM would have that would fit the bill? Thanks
back@it is offline
Old 08-24-2007, 08:55 AM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: "Lacquer-based Varnish" ?
That's weird
I'm curious as to what is spec'd that way, and why
I'm not sure you'll find that at SW or BM
Though many BM stores are independent, and can carry products other than BM branded ones...might be worth a phone call to your local one
Any woodworking or marine shops nearby?
Signature Quote
slickshift is offline
Old 08-24-2007, 09:43 AM   #3
Teetorbilt's Avatar
As far as I know there is lacquer and there is varnish, totally different animals.
Albert Einstein
Teetorbilt is offline
Old 08-24-2007, 09:59 AM   #4
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Sounds to me like the want lacquer. I've heard lots of people refer to poly as varnish with no intetions of using varnish.
"What are you going to do to that? I'm going to varnish it. With varnish? Yeah, I got this Minwax. That's polyuerethane. Yeah? What's the difference?"
I think you've just got somebody that is using the term varnish as a generic term meaning to top coat something with a protective finish.
Mike Finley is offline
Old 08-24-2007, 11:45 AM   #5
back@it's Avatar
That's what I've always thought!
I bet you are right about that! Guess I should just call the architect and ask! Thanks..
back@it is offline
Old 08-24-2007, 02:33 PM   #6
...jammin
slickshift's Avatar
There's lacquer and shellac varnishes
It's just really weird that someone spec'd it for (what I'm assuming is) a house hold or commercial trim job
I suspect the others are right
It's a mess up of terms, they prolly want poly or something
Or some architect heard from another one that "lacquer-based varnishes are the best, but painters won't tell you about that because they don't want the job to last too long because then they don't get repeat business...so don't let them tell you not to use it"
That happens a lot with those guys
Signature Quote
Old 08-24-2007, 08:43 PM   #7
back@it's Avatar
It's a kitchen make-over in a nice old house in a well established historic distric here in town. And yes, it is what they are wanting on the trim work. I didn't get a chance to talk with the architect's office or the GC today but I need to get the quote to the GC by Monday afternoon!
back@it is offline
Old 08-24-2007, 11:41 PM   #8
BT006's Avatar
Sealers:
A sealer is a substance used to protect a surface from oxidation, natural deterioration and physical abuse. Numerous types of sealers are found commercially, each providing a specific solution for a sealers needs.
The term ‘varnish’ has become a common word referring to a general sealer. There are considerable differences between varnishes and other sealers and for accurate results the proper terminologies should be used.
Varnish:
Varnish typically is petroleum based or tree sap based clear sealer. Varying degrees of sheens are found, from matt (flat), to eggshell, satin (pearl), semi-gloss and gloss (high gloss). Most commonly used for furniture, floors, objects, and the ship building industries. Varnish comes in 2 basic categories, oil based and water based. Each category has different types, for example, Spar varnish, Damar varnish, re-touch varnish.
Oil: Apetroleum based product that is very durable. It has a longer drying time than it's acrylic counterparts, and some forms may slightly yellow over time, and when exposed to natural light. Recommended for commercial use and any areas that have high traffic zones.
Solvent: Mineral spirits, turpentine
Acrylic: Acrylic varnishes have now greatly supplemented its longer drying oil based counterparts. The quick application time, fast drying, durability and easy clean up make acrylic varnishes ideal for interior uses. Acrylic varnishes remain clear after drying and are commonly used for floor sealing, objects and furniture.
Solvent: water
Never shake varnish. Only stir it to mix properly. Shaking will create air bubbles in the varnish. This can result in poor application and an irregular finished surface.
A few excellent varnish products for floors, furniture and objects are latex varnish , a latex-water based sealer, and oil varnish , an oil based sealant.
Shellac:
Shellac is produced from the secretions of a bug, deposited on branches of trees in India. Shellac can be diluted with denatured alcohol to make the shellac workable, or to dissolve and remove shellac. Typically used on furniture, shellac can be used as a fast drying sealer. French Polish and simulated lacquer techniques employ the use of shellac as a sealer.
Solvent: denatured Alcohol
White pigmented shellac: Products such as BIN is commercially available. Essentially a combination of shellac, denatured alcohol and titanium dioxide, pigmented shellac makes an excellent fast drying sealer, especially good for covering water spots, bare wood that has sap exposure and surfaces that may have slight grease or wax build up.
Solvent: denatured alcohol
Warning: Shellac is highly toxic. It has a strong odor and should always be used in a well-ventilated area. Respirators and protective gear is recommended with the use of any shellac product.
Lacquer:
Used commonly in the industrial environment, particularly in the automotive industry and furniture production. Lacquer is well suited for mass production processes. Lacquers are typically made of nitro-cellulose, cellulose acetate, and other forms of cellulose. Lacquers dissolve in special solvents such as acetone, ethyl acetate, butyl alcohol, etc.
Lacquers should not be used in Fine Art painting as its level of permanence is low. Pigmented lacquers display signs of deterioration in as little as 10 years, from exposure to daylight.
Lacquers are often used because of their fast drying time.
Natural lacquer (Oriental): Exude natural from trees in a liquid state. Natural lacquer is used for local production and is not exported.
Solvent: Lacquer thinner
Warning:Lacquer is highly toxic. It has a strong odor and should always be used in a well-ventilated area. Respirators and protective gear is recommended with the use of any lacquer product.
Urethane, Polyurethane and Varathane:
These are derivatives of varnish. Each maintains a particular property that makes it suited for specific functions. Primarily due to hardness, elasticity, and yellowing qualities over a period of time and exposure to light. Floors, furniture and objects are ideally suited for urethane sealers. Surfaces requiring a barrier of protection to oxygen, water or moisture, and physical damage over the course of use are candidates for protection of a varnish product.
Solvent: Mineral Spirits, turpentine, turpenoid.
BT006 is offline
Pebble based patio highlife77 Masonry 9 10-23-2007 10:04 PM
tips on removing oil based stain from hinges davidanbess Painting & Finish Work 10 07-10-2007 02:25 AM
faux finish on oil based cabinets lornmastro Faux Finishes 1 06-27-2007 01:19 AM
Thoughts on Water based woodmagman Painting & Finish Work 5 04-13-2007 10:05 PM
oil based then poly lornmastro Painting & Finish Work 4 03-18-2007 11:18 PM
