Knots(bleeding)
Old 05-30-2004, 08:21 PM   #1
sherry_31's Avatar
Knots(bleeding)
Can anybody tell me of something that works to stop knots from bleeding thro? Besides Shellac, Kilz or aluminum paint (none of these seems to do it)
The subject is...... regular interior preprimed trim with white semigloss over.
Thanx
sherry_31 is offline
Old 09-04-2004, 11:54 AM   #2
Quality Painter's Avatar
Lightbulb
Re: Knots(bleeding)
Thanx
Sherry
knots can be a real pain, more then likely the wood is dry but the knots are not. lol, no pun intended. knots will take 2 years to cure out all the way, even if your using kiln dryed wood. i have had many problems with knots causing blissters and bleeding . i would try to sand off all material on knots and run a heater at full blast for a few days, then use a water based poly over them then primer with kills then paint. let me know if you have any luck . peace, dave out :Thumbs:
Quality Painter is offline
Old 09-04-2004, 04:14 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Knots(bleeding)
I use BIN, works every time.
ProWallGuy is online now
Old 09-11-2004, 12:33 AM   #4
Re: Knots(bleeding)
whats BIN ? thanks , dave
Old 09-13-2004, 11:07 PM   #5
ProWallGuy's Avatar
Re: Knots(bleeding)
It's a shellac-based primer, Zinsser makes it, called B-I-N.
Old 09-26-2004, 10:28 PM   #6
sherry_31's Avatar
Re: Knots(bleeding)
Originally Posted by Quality Painter
Sherry
Hi Dave
They sure are a pain, i think you answered my question well as weve tried a # of different products including Bin as Prowall Guy described and that hasnt worked either not work either...Anyway i'll think i something myself and maybe i'll become rich haha Thanks
Sherry
Old 11-02-2004, 06:43 PM   #7
premierpainting's Avatar
Re: Knots(bleeding)
[Spray BIN on the knot with two coats, normally works for us
premierpainting is offline
Old 11-02-2004, 06:44 PM   #8
Re: Knots(bleeding)
Thanx
Try spraying BIN with two coats- usually works for us
Old 12-12-2004, 07:52 PM   #9
painting contacor
frank's Avatar
Re: Knots(bleeding)
Thanx
bins is a great stain blocker great for knot bleed allways prime preprimed to guarante a long lasting paint job.
frank is offline
Old 12-12-2004, 07:53 PM   #10
painting contacor
frank's Avatar
Re: Knots(bleeding)
binz
frank is offline
Old 12-12-2004, 11:49 PM   #11
sherry_31's Avatar
Re: Knots(bleeding)
Thanx Frank and others i'll remember this next time i come across this
Sherry
Old 12-30-2004, 08:55 AM   #12
PlainPainter's Avatar
Re: Knots(bleeding)
I read that someone here hasn't had good luck with shellac killing knots?!?
BIN is a white pigmented shellac, and has always worked on every knot
I have applied to it. I also read someone say it takes 2 years for knots
to fully cure, I have painted over wood that was lumbered 50 years ago, and
the knots are still 'active'. What you have to understand is that in order for
a primer to kill a knot stain, it has to polymerise - another word for dry - before the tannins can bleed thru. And BIN being Alcohol based, dries the fastest of any of the 'quick' dry primers. Although lately is seems, that some manufactureres and paint stores are saying shellac based primers are 'old' technology. And are now pushing quick dry primers formulated with Vinyl-Alkyd Toluenes, such as California's Wipe out primer, or Ace alkyd Stain Halter.
And Pratt and Lambert's odorless stain killer, for exterior work especially, since Bin is very sensitive to moisture. Although, I have experimented with Applying Pratt and Lambert Accolade paint to wood previously done with poly, without priming. And the poly killed all the knots great.
-PlainPainter
PlainPainter is offline
Old 03-01-2005, 07:53 PM   #13
Yes master.
MasterStrokes's Avatar
Re: Knots(bleeding)
I didn’t think a whole lot could bleed through shellac. They must be some damn nasty knots. I do remember a trim with one knot hole that would bleed sap in tear drops. I ended up cutting it out and reforming the trim with Bondo. It worked.
If nothing we do matters, then all that matters is what we do.
MasterStrokes is offline
Old 03-16-2005, 06:20 AM   #14
IUPAT Member
shunter's Avatar
Re: Knots(bleeding)
Zinzer is one of the best products out there to use...
I highly recomend it!!!
shunter is offline
Old 10-08-2006, 03:02 PM   #15
metomeya's Avatar
Re: Knots(bleeding)
Funny, sherry keeps saying shes used BIN, but everyone keeps telling her BIN.
Feel like no ones listening to you?
Sounds to me you need to use a product to remove as much tannin/sap as possible.
Look at your home improvement store, I know Olympic at Lowes came out with a new product for decks to remove tannin for red wood and such. I'm not sure if there is a product made to remove sap from wood, but look in the paint section. If that works, still use 2 coats of BIN on it (bleed on the primer through is always normal, but the primer should "lock" the tanning)
Heres can idea that might not work, but could be worth a try, try soaking the knot with mineral spirits, then using a dry-vac to suck the tannin. Again, not sure it if it would even work, but worth a try.
If none of that works (atleast clean it as best as possible) I guess what PlainPainter suggested would be your best shot, the Vinyl-Alkyd Toluenes paints.
metomeya is offline
Old 10-08-2006, 03:04 PM   #16
metomeya's Avatar
Re: Knots(bleeding)
Found a site that recommeneded a product called automobile finish sap remover.
http://www.stretcher.com/stories/01/011105m.cfm
metomeya is offline
Old 10-08-2006, 03:07 PM   #17
ProWallGuy's Avatar
Re: Knots(bleeding)
You're probably right. Most if not all the people on this thread have been gone for over a year.
Old 10-08-2006, 03:08 PM   #18
metomeya's Avatar
Re: Knots(bleeding)
lol, didn't even notice
metomeya is offline
Old 10-08-2006, 06:10 PM   #19
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Knots(bleeding)
...and it's under picture posts, which I don't think existed back then
Lol
I think I'll move it
Signature Quote
slickshift is offline
Old 10-08-2006, 06:54 PM   #20
Miniroller's Avatar
Trade: Painter
Re: Knots(bleeding)
Wipe knots with xlyol, then put an immediate coat of B-I-N on. Wait 1/2 hour, put 2nd. coat B-I-N on. Wait 45 min. and put 3rd. coat B-I-N on. No knot should show through (works on new pine or cedar anyways, with cedar may have to prime twice.
Miniroller is offline
