Kilz Primer - Blistering And Bubbles
Old 10-20-2005, 08:09 PM   #1
Wild Blue's Avatar
Good evening. I have a question as far as using the kilz primer. We applied Kilz primer to an exterior aluminum tailer as suggested. It was totally cleaned (pressure washed 2 days prior to application). We sprayed an even coat and even 2 coats in some areas to the clean and dry aluminum. When we came back to the job the next morning, where the kilz primer was applied, the surface was all bubbled and blistered. What would cause this? It was a mess and needed sanding. the surface was entirely dry upon application.
Another question - In some areas we sanded then applied the regular top coat of paint, it still blistered and bubbled on the 2nd morning.
Thank you for your rapid response.
Wild Blue is offline
Old 10-20-2005, 08:16 PM   #2
Teetorbilt's Avatar
Re: Kilz Primer - Blistering And Bubbles
Sorry that I can't help with your problem. On aluminum, I have always used a zinc-chromate primer following proper prep work.
IMHO aluminum is a headache to be avoided. I can elaborate.
Albert Einstein
Teetorbilt is offline
Old 10-20-2005, 08:27 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Whoever suggested using Kilz to prime aluminum was a knucklehead.
I assume it was the latex flavor of Kilz?
ProWallGuy is offline
Old 10-20-2005, 08:31 PM   #4
Teetorbilt's Avatar
I don't paint much but IMHO Kilz waterbase sucks. I'm not going there again, too many better products.
Albert Einstein
Old 10-20-2005, 08:44 PM   #5
Wild Blue's Avatar
What would you suggest then as a primer on aluminum trailers that are down to or almost down to bare metal? We are also getting these little dots like the size of pinheads - bleedthru we need to stop. We prefer a latex if possible.
thanks again so very much for all who answered - aluminum sure is a pain!
Old 10-20-2005, 08:51 PM   #6
ProWallGuy's Avatar
Don't get your hopes set on latex, the PQI recommends a solvent based primer.
I use BM 206.
Old 10-20-2005, 10:24 PM   #7
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Doh!
Kilz is not something to use as a full primer coat. If you're not going to use what PWG suggested try DTM from SW. No primer needed on aluminum with DTM, just proper cleaning.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-20-2005, 10:31 PM   #8
ProWallGuy's Avatar
DTM is also good stuff IMO.
I still get a little freaked out over no primer. I use the DTM on small stuff, like wrought iron railings, or doors. Something large/high $$$ I'd prefer to CMA and prime it anyways.
Old 10-20-2005, 11:35 PM   #9
Pro Painter
AAPaint's Avatar
I just thought of something else. Did you scrub that aluminum trailer down when you pressure washed it? What was it previously coated with, and was the surface chalky?
PWG - I'm with you on the priming for sure. I just see that as a basic must do...the no primer is the actual manufacturer recommendation, but old habbits die hard for sure!
The thing I like about DTM is it comes in a number of different flavors, acrylic, enamel, urethane, etc. I'm actually using the urethane on a project right now. It's an iron railing, as a matter of fact! Guess what though...I'm priming it, lol!
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-21-2005, 12:00 AM   #10
ProWallGuy's Avatar
BTW, I say the bubbles/blisters are from some sort of contaminant, not necessarily due to poor adhesion.
Old 10-21-2005, 06:33 AM   #11
747's Avatar
I do remember when slickshift recomended zinsser bullseye 123 primer sealer for my sister to prime her bathrooms walls with. I got home read the back of the can and it said you could prime aluminum with it. I remember thinking wow this stuff will stick to anything. I not recomending this. I think you should listen to pwg and AA i was just saying. Then she went with the zinsser permawhite mold and mildew resistance like slickshift recomended. Here bathroom walls look awesome when she was done. Alot better than i thought.
747 is offline
Old 10-21-2005, 07:18 AM   #12
Exroadog's Avatar
Trade: paint
zinc chromate. It works for aircraft!
Exroadog is offline
Blistering Paint Eric S Painting & Finish Work 13 10-02-2006 03:27 AM
