Kilz Oil Or Zinsser Oil To Cover Nicotine Walls?
Old 11-15-2011, 10:53 PM   #1
seanheil's Avatar
Hello Painters,
I don't have a lot of experience in residential repaints and I'm wondering if you guys would recommend Kilz Original or Zinsser Cover Stain for covering nicotine covered walls and ceilings. Thanks.
seanheil is offline
Old 11-15-2011, 11:07 PM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Kilz Oil Or Zinsser Oil To Cover Nicotine Walls?
Zinsser.
Not that I don't think Kilz will cover the stains but my experience is that Zinsser is just a better product all around.
CrpntrFrk is offline
Old 11-16-2011, 12:19 AM   #3
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,300
I like zin also.
SuperiorHIP is offline
Old 11-16-2011, 03:50 PM   #4
shives's Avatar
Trade: paint sales
you should use a shellac base primer, cause that will reseal and stop all the smell from the smoke damage (bin)
shives is offline
The Following 2 Users Say Thank You to shives For This Useful Post:
aptpupil (11-28-2011), Metro M & L (11-28-2011)
Old 11-16-2011, 08:59 PM   #5
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
that was my experience too. I primed an apt ceiling with oil primer and later when trying to do ceiling white the smoke stains reappeared, guess it wasn't double primed, sure I didn't wait the whole day for it to dry, but the shellac primer was once over and far less disappointment,,, or you could oil prime and then an oil in flat or just too coats of oil primer , who's looking anyhow. There is an oil primer that is extra white available I forget the brand.,could be kilz. As for the walls, they are usually wipable, and color unless you have to have pure white can usually hide it up.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 11-19-2011, 06:59 PM   #6
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,041
Kilz hasn't let me down yet. Although the Zinsser is a good product too.
This is from a older thread of mine: http://www.contractortalk.com/f26/nicotine-before-after-photos
Originally Posted by Sir Mixalot View Post
Just finished a job in Cocoa Beach, FL where the guy that lived in the condo before my customers bought it was a hermit and smoked in it for 25 years.
Removing the popcorn texture:
After the ceilings were redone and the walls were painted:
-Paul
Sir Mixalot is offline
Old 11-19-2011, 07:08 PM   #7
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Pro block all the way for me!
ohiohomedoctor is offline
Old 11-20-2011, 05:45 PM   #8
semi-skilled laborer
ModernStyle's Avatar
Trade: Professional Painting
Rewards Points: 1,186
BIN is the best, pain in the butt to work with but dries fast and seals in the stain and the odor. Cover stain will sometimes work but it's smell will stick around a lot longer then BIN. Kilo has failed me a few times so I don't use it anymore.
OwensboroPainting.com
ModernStyle is offline
Old 11-27-2011, 09:36 PM   #9
willfreshcoat's Avatar
Trade: painting
pigmented shellac....nothin better
willfreshcoat is offline
Old 11-28-2011, 08:43 AM   #10
HDPaintPro's Avatar
Trade: Painting 23 years
The shellac base will do the trick - but its pretty harsh (smell wise) so make sure you vent. Also, you may find that it is not cost effective right now (almost doubled in price) due to supply shortage.
Second option would be Zinsser Cover Satin oil primer. Big Box will have it cheapest.
HDPaintPro is offline
Old 11-28-2011, 09:22 AM   #11
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,866
Curious to know....do you try to clean the nicotine off the surfaces first and with what ?
We Fix Houses is offline
Old 11-28-2011, 10:13 AM   #12
HDPaintPro's Avatar
Ideally speaking - yes. But, it is time consuming...time is money.
Consider that most of all the smoke rose, so the ceiling for sure gets primed, next is any crown and then just clean the walls with TSP. My point is that you will still want to prime the walls regardless.
Doing this one time is the payoff. Not having to deal with it again.
Bathroom Walls weeping... HELP hbl164 Painting & Finish Work 19 09-08-2016 12:40 PM
Wrapping walls on the deck? FitzH2O Construction 12 01-20-2013 10:52 AM
Straightening Walls jason1980 Framing 22 12-02-2010 07:37 PM
Repainting interior block walls - Drylok? CarrPainting Painting & Finish Work 6 11-19-2010 05:55 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
