Old 07-18-2006, 08:44 AM   #1
Trade: Handyman
Just a roller!
Hi, I'm new to this site but thought I would throw this out there. I do a lot of work for a property maintainence company and do a lot of touch up painting and painting entire units. I'm usually painting the same color and have found that by using a small 1"x7" roller with a 3/8" nap and an 18'' roller I don't have to tape anything off. I use a drywall knife as a guide and run the roller along it along cupboards, baseboards, etc. I usually use a 14" knife but in tight spots I use a smaller one. I even cut in around the ceiling with it. It saves me a lot of time over taping everything off or cutting in with a brush and you don't end up with brush marks. Hope this helps someone else save time.
yikkle is offline   Reply With Quote
Old 07-18-2006, 01:09 PM   #2
SgtBaldy's Avatar
Rookie
Tampa Painters
SgtBaldy is offline   Reply With Quote
Old 07-18-2006, 04:53 PM   #3
painterofeverything
Trade: residential painter
Send a message via Yahoo to painterofeveryt
sgt baldy...all this guy offered was some free advice,if you already knew it,politely say thanks...no disrespect intended.
painterofeveryt is offline   Reply With Quote
Old 07-18-2006, 05:19 PM   #4
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
I'm sure that technique would work for property maintenance, but doubt it would fly on a quality or high-end repaint.
ProWallGuy is offline   Reply With Quote
Old 07-18-2006, 05:56 PM   #5
SgtBaldy's Avatar
Sry, what I meant was he needs to improve his brush skills. There are some times the 'ol shield and whizz technique comes in handy but if you cut in enough with a brush then it is quicker and can achieve tighter edges. Plus if you tip out your cut in then you won't see brush marks.
Was just kidding around with the rookie comment though.
Tampa Painters
Old 07-18-2006, 07:30 PM   #6
painterofeverything
no sweat at all,had a couple of beers and wondered what was up with that ! thanks for the reply ...
Old 07-18-2006, 11:14 PM   #7
Painting & Restoration
Trade: Painting Contractor
I am a painter and very good at using a brush, but i do use a guide sometimes for window sashes. It cuts down on time and lefthanded painting since im righthanded.
GoodPainter is offline   Reply With Quote
Old 07-20-2006, 09:06 PM   #8
Trade: Handyman
Like I said, I do mostly rentals not high end paint jobs. I can run along the baseboard and all of the trim quickly and save a lot on my back trying to cut in baseboard. I don't claim to be a "painter", just a handyman. I just painted a three bedroom apt. in six hours whether that is good or bad I can't say. It keeps me out of the bars and off the streets. Just remember; "If the women don't find you handsome, they should at least find you handy".
Old 07-21-2006, 05:20 AM   #9
...jammin
slickshift's Avatar
Trade: Rock Disciple
Originally Posted by yikkle
...whether that is good or bad I can't say....
Pretty good for a Property Mgr. Special (one coat, one color, rolling the trim)
If you do a lot of those and there's usually no furniture in them, it may be worth it to invest in a sprayer and get a good taping system down
Signature Quote
slickshift is offline   Reply With Quote
One more airless power roller question steve-in-kville Painting & Finish Work 5 09-19-2008 10:09 PM
Titan power roller... My first impressions steve-in-kville Painting & Finish Work 0 06-17-2007 10:22 AM
Dried roller cover removal? steve-in-kville Painting & Finish Work 17 04-12-2007 07:26 AM
2 Power Roller Options... which is better? kenrie Painting & Finish Work 8 10-12-2006 03:19 AM
Roller marks in dark paint. cutnroller Painting & Finish Work 10 08-03-2006 10:09 PM
