I've Got Some Problems With Poplar Steps That I Stained
Old 12-29-2007, 10:00 PM   #1
Dorman Painting's Avatar
Trade: Painting Contractor
My builder is building a fine home for himself and decides to save himself some money and put in poplar steps instead of oak steps. The poplar wood simply doesn't take stain as well, it really doesn't look good.
Here's the problem, some of the steps look as if they've gotten stains showing through the stain. It looks as if darkish circles appear, maybe someone spilled water or something. I'm not sure, but I'll palm sand the steps and see if I can get the stains to dull down a little and then restain.
Any ideas on how to handle this situation? I can't believe this guy put poplar wood in for treads, oak should be the order of the day IMO. Poplar just doesn't stain that well and is more for paint grade. Give me some ideas on this. Thanks.
Dorman Painting is offline
Old 12-29-2007, 10:12 PM   #2
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
Re: I've Got Some Problems With Poplar Steps That I Stained
Poplar is a paint grade wood. There is variation in the wood coloring. Some parts are darker, sometimes green, while other parts are lighter like birch. That's is why it's always used a paint grade hardwood. You're right, should've spent a couple more bucks and bought oak.
In_Mexifornia is offline
Old 12-29-2007, 10:12 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Did you apply a sanding sealer before the stain?
ProWallGuy is offline
Old 12-29-2007, 10:21 PM   #4
Guru
paint_booger's Avatar
Trade: Union Paint & Drywall
Dorman: "Here's the problem, some of the steps look as if they've gotten stains showing through the stain. It looks as if darkish circles appear, maybe someone spilled water or something. I'm not sure, but I'll palm sand the steps and see if I can get the stains to dull down a little and then restain."
Been there ... done that. For h2o stains ... bleach!
paint_booger is offline
Old 12-30-2007, 12:47 AM   #5
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Those spots are probably tannin bleed.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 12-30-2007, 03:10 PM   #6
Joewho's Avatar
Trade: Painter
Whink
http://www.alwaysbrilliant.com/aa//D...in_remover.htm
Joewho is offline
Old 12-30-2007, 04:14 PM   #7
Bleach? How exactly do you do that? Rag it on or what?
I went up there today and palm sanded the steps like a madman, it certainly seemed to help. But IMO, the steps just aren't what I'm used to. I like the consistancy of oak steps, you don't get the color variation. This guy is a very picky builder and I'm sure it's all going to be my fault. I told him poplar doesn't stain well and his response was "I was trying to save a few bucks". Oh well, you get what you pay for.
Old 12-30-2007, 04:37 PM   #8
nick@nite
THINKPAINTING's Avatar
What kind of builder picks poplar for finish work like that? He could have used pine to save a few bucks, but how much did he really save? How many steps are there.
THINKPAINTING is offline
Old 12-30-2007, 05:22 PM   #9
...jammin
slickshift's Avatar
Trade: Rock Disciple
You are being kind
I would have said "What kind of bonehead picks poplar for finish work like that?"
Seriously, pine would be a better choice to save a few bucks
At least it can take a stain
I've never seen poplar stained that didn't look like butt
Paint it, or replace it
Signature Quote
slickshift is offline
Old 12-30-2007, 06:17 PM   #10
BigDa's Avatar
Trade: General Contracting, Electrical Contracting, and Demolition.
I have done tons of finished steps, install and finish. If this contractor is as "picky" as you say he is, he should have known that poplar was not the way to go. I agree about the condition and bleach should be used, nevertheless I have never seen poplar stained that i would have satisfied with. I have a shaper and the bits to make stair treads, but I never do unless its an exotic wood needed. The reason, I can buy oak treads for around 25 bucks. This guy did not save any money. Does this "picky" contractor realize what 6 months of traffic will do to this softest of the hardwoods--poplar. I know it is considered a hardwood, but paint grade, man! I love working with poplar for paint grade. It planes, cuts, and sands easy, without a lot of wear to your equipment. It is a shame the painter will forever get the blame for this guys ignorance. Next time you can refuse to do this. It's not being a "know-it-all", if you speak from experience. Good Luck, Bro!
BigDa is offline
Old 12-30-2007, 07:13 PM   #11
Painter James's Avatar
Trade: Painting, Drywall, Flooring, Fencing
The "bleach" isn't the "clorox" variety, like in mold remediation. It's Wood Bleach. Follow the directions with the manufacturer, as there are a couple of varieties, but basically after you apply it, you'll have to neutralize it. It works well.
As to staining poplar--I wouldn't have (sorry to say it like that). YOU are the expert, not the builder--I don't care how many homes he's built. He was telling you how to do your trade, and that wasn't wise.
At the very least, maybe a wood conditioner might have helped some, but overall staining poplar is a bad idea.
Better results would be to use a NGR (non-grain-raising) dye, shot with an HVLP, but even that would not come out as well as paint for poplar. A good quality SPAR urethane/varnish (marine variety) would have helped too, instead of stain (it darkens the wood some).
Just some thoughts.
Painter James is offline
Old 12-30-2007, 07:16 PM   #12
never heard of that--usually used SS after staining or dyeing--doesn't the stain need to penetrate the wood fibers? usually use SS before lacquer, for texture purposes (ensuring a smooth surface). Seems like sealing the grain wouldn't allow for staining.
Just curious.
Old 12-30-2007, 07:32 PM   #13
New York City
eastend's Avatar
Trade: historic woodwork restorations
use a thinned down sanding sealer - as a wash coat- to "condition" wood. This will help provide for a more even staining, and minimize the blotching that poplar is famous for.
eastend is offline
Old 12-30-2007, 07:42 PM   #14
painterman's Avatar
Trade: Historic Restorations
you can't make chicken soup out of chicken sh*t Staining that material is a big waste of time. Time spent sanding it is a bigger waste of time. Just paint them or maybe add a faux finish to them to look like oak.... now thats a money saver!!
painterman is online now
Old 12-30-2007, 07:42 PM   #15
Teetorbilt's Avatar
I want to know when Poplar was 'upgraded' to a hardwood. Up until recently it was always considered a softwood.
Want proof? Burn some. The stuff goes so fast that it's only marginal kindling.
Albert Einstein
Teetorbilt is offline
Old 12-30-2007, 07:51 PM   #16
Well, I KNEW poplar wasn't stain friendly, but after reading all of the responses I'm ready to whip his ass. It doesn't look good and the rest of the job looks A++. He keeps coming in the house and rubbing his face against the flutes and jambs because I get them so slick, just like glass. He's absolutely nuts over my trim job, I go WAY beyond what most painters do on trim work.
However, my staining experience is certainly not my strong suit, but I've produced some VERY nice stain pieces. Stain work isn't as popular as it used to be and it's skipped a generation of painters to tell you the truth. If he gets on me about this, I'll tell him poplar is FAMOUS for a blotchy finish and the TRIM carpenter should've told him this too!!
Old 12-30-2007, 08:16 PM   #17
jackrabbit5's Avatar
Trade: Paperhanger/painting contractor
Just tell him that the blotchyness is part of the inherent beauty of that particular species of wood. Some people don't like to see seams in their wallpaper. If that's the case, then they should steer clear of grasscloth. By the same token, if they don't like the blotchy look, they should go with something other than poplar.
Stacy
S B Bolson & Sons
jackrabbit5 is offline
Old 12-30-2007, 08:18 PM   #18
...jammin
slickshift's Avatar
Originally Posted by jackrabbit5 View Post
...if they don't like the blotchy look, they should go with something other than poplar.
Lol..basically, yeah
Yes it can be deceiving as "hardwood" merely refers to the tree being deciduous
Balsa (what we made gliders out of) is a hardwood...funny but true
Signature Quote
Old 12-30-2007, 08:20 PM   #19
...jammin
slickshift's Avatar
(deciduous= loses it's leave in the winter, or dormant in the dry season)
Signature Quote
Old 12-30-2007, 08:35 PM   #20
wannabe
WNYcarpenter's Avatar
Trade: carpentry
What species of tree is commonly referred to as poplar (in the building industry) which is actually not a poplar species......?
WNYcarpenter is offline
Construction Records Problems PalAl2000 Commercial Construction 5 05-15-2007 07:56 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
resurface concrete steps haskl33 Masonry 0 10-04-2006 10:13 PM
Solving Problems dayspring Off Topic (Non Trade) 13 06-15-2006 08:45 PM
Question about sandblasting some metal steps Dorman Painting Painting & Finish Work 3 06-10-2006 12:21 AM
