Interior Stucco Fireplace
Old 05-20-2007, 09:17 PM   #1
Red
Red's Avatar
I have a fireplace in a new construction, and the entire surround is going to be stucco (osb, #15 felt paper, metal lath, stucco). I have tried to read all of the posts about painting stucco, but I haven't found anything that applies to this unique situation. My concern is what type of paint can be used (primer, final coat, etc.) for this interior application? Has anyone had this type of situation, and if so, was the stucco painted or was the color always mixed into the stucco? Thanks for any help you can give!
Red is offline
Old 05-21-2007, 06:26 AM   #2
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Re: Interior Stucco Fireplace
SW Loxon Block Surfacer is what I would recommend.
Rich
Richard is offline
Old 05-21-2007, 09:18 AM   #3
Red
Red's Avatar
Thanks for your help! I will check that out.
Red is offline
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Gas Fireplace - To Vent or Not Hardibuilt General Discussion 8 05-08-2007 10:58 AM
Fireplace Insert Raised off the Slab Hambone Masonry 14 04-22-2007 09:54 PM
Fireplace Insert Raised off the Slab Hambone Construction 7 04-20-2007 11:57 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
