Interior Paint On Exterior
Old 10-15-2009, 11:01 AM   #1
jjocsak's Avatar
Trade: Residential Remodeling
I accidentally painted a couple of porch posts with interior semi-gloss paint before I realized it.
What are my best options to correct this?
Thanks
Jeff
jjocsak is offline
Old 10-15-2009, 11:03 AM   #2
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Re: Interior Paint On Exterior
strip it raw and start again! he he.
Darwin is offline
Old 10-15-2009, 03:09 PM   #3
jjocsak's Avatar
What would be the harm of giving it a topcoat of exterior?
Jeff
jjocsak is offline
Old 10-15-2009, 09:32 PM   #4
Metro M & L's Avatar
Trade: Painting & Flooring
I don't know. Put it on there and plan on getting a call next year to find out what happened!
"Yeah... It's worthy of a sig quote."
Metro M & L is offline
Old 10-15-2009, 10:04 PM   #5
jjocsak's Avatar
Actually it's my own house, go figure.
Jeff
jjocsak is offline
Old 10-15-2009, 11:07 PM   #6
Knowledgeable Tinter!
Faron79's Avatar
Trade: Painting/Hardware Retail
Seriously...there's little worry here!
Technically, typical Interior resins are a little harder. Exterior binder-resins are usually slightly more "flexible".
It'll probably wear just fine. Slight odds of it cracking earlier, depending on the wood' movement.
Faron
Faron79 is offline
Old 10-15-2009, 11:38 PM   #7
jjocsak's Avatar
Faron
Thanks, I was thinking the same thing but wasn't quite sure.
Jeff
jjocsak is offline
Old 10-16-2009, 08:45 AM   #8
NAV's Avatar
Trade: commercial building restoration
I have been told by Paint Reps that if you apply interior coatings on an exterior they will fail.
If you coat over them with an exterior product they will still fail. what will happen first is the exterior top coat will become chalky within a year and then you will have the peeling and blistering.
I have not tried it to see if my Rep is correct but if it is your house I say let it go and see what happens.
NAV is offline
Old 10-16-2009, 08:59 AM   #9
jjocsak's Avatar
Thanks NAV.
I was an interior semi gloss enamel if that matters.
I guess it's time for an experiment.
Jeff
jjocsak is offline
Old 10-16-2009, 10:31 PM   #10
House Painters Reading PA
4thGeneration's Avatar
Exterior and Interior paints are manufactured to hold up to the elements they are meant to be applied in. An interior paint used as a first coat on an exterior application with an exterior paint applied over that is just trouble. It will not last and you will have bubbling paint because the interior coating will not hold up. Even with a top coat of exterior on it.
I know sometimes like SW can get confusing when using Super Paint because they make both Interior and Exterior for the same name. Thats why i always check, check and recheck all the labels. We actually had new people at the paint stores shoot an exterior color for an interior paint and vica versa.
House Painting and Roof Cleaning by Sutton provides
House Painting Services in Berks county PA
for all Interior and Exterior Projects
484-334-3999
4thGeneration is offline
Old 10-17-2009, 05:18 PM   #11
jjocsak's Avatar
This is what the manufacturer said:
You may apply an exterior paint over the existing interior paint. This will seal the coating and prevent any future problems.
Jeff
jjocsak is offline
Old 10-17-2009, 06:01 PM   #12
Jeff
Not meant to burn you, but in my opinion that Rep may be mixing his meds...
484-334-3999
Old 10-17-2009, 08:05 PM   #13
jjocsak's Avatar
I think you may be right....
Jeff
jjocsak is offline
Old 10-18-2009, 06:17 AM   #14
Frankawitz's Avatar
The paint will peel strip and repaint
Frankawitz is offline
Old 10-18-2009, 07:19 AM   #15
Wolfgang's Avatar
Trade: Painting & Remodeling
First thing is to turn in your Painters Card.... just kidding. 6 years ago I had a guy do the same thing to his porch columns, we went over it with oil-based CoverStain primer and topcoated it with exterior. Other than the regular exterior grime they've held up through the Nebraska weather extremes. Might want to give it a shot.
Wolfgang is offline
Old 10-18-2009, 07:34 AM   #16
jjocsak's Avatar
Wolfgang, very interesting.
Do you think it was the oil based that was the key or just the primer/topcoat application by itself?
I'm also curious if the interior coat was also oil?
Jeff
jjocsak is offline
Old 10-19-2009, 07:08 PM   #17
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
I think you should be ok if you prime it with an oil primer and topcoat with an high quality exterior paint.
give it a try and let us know in the spring!
vandyandsons is offline
Old 10-19-2009, 07:29 PM   #18
Dave R's Avatar
Trade: Home renovation and repair
Last year I was working on a job where the painters painted the exterior of the house we were renovating with interior paint. They couldn't speak or understand English so they didn't understand when we tried to tell them. The GC didn't make them redo it so the interior paint stayed on. I went by the house a couple weeks ago and the paint still looks good.
Dave R is offline
Old 10-19-2009, 07:33 PM   #19
Framer53's Avatar
Trade: Framing
Thanks NAV.
Jeff
Don't worry, been there done that 8 years ago. Just scraped and repainted this year!!
Framer53 is offline
Old 10-25-2009, 11:42 PM   #20
Jeffrey Watson's Avatar
Trade: carpenter
I would not do anything. It might hold up depending on wheather conditions. Wait and see, if it holds up Great! If not fix it after it fails. I mean you got better things to do Right
Jeffrey Watson is offline
What to put on the Exterior of a Timber Frame Markon Painting & Finish Work 6 12-13-2011 11:11 PM
Paint or stain on hardi plank? Jer Painting & Finish Work 25 12-24-2009 01:10 PM
exterior mahagony hand railings nhshorty Painting & Finish Work 3 09-28-2009 09:09 PM
leak under sunroom exterior wall on slab jrcuts Framing 7 01-09-2009 06:17 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
