Interior Garage Concrete Block
Old 12-03-2006, 01:39 PM   #1
Painting & Restoration
GoodPainter's Avatar
Trade: Painting Contractor
Hello to all,
I wanted to have all your opinions on painting the Interior of a garage that is cinder blocks. Also Int. doors which are fiberglass.
This is for my friend so I want to do it right the first time, but he wants to do it the cheap way(which is fine)
I will be spraying most likely, with possible backrolling(never sprayed block b4) MY choice paints are BM and Coronado, but going the cheap route he wants to use L*wes brand Fasthide(I personally have used this and it works nice just need more coats then normal)
Now the garage is painted on the outside but still gets moisture on the Int. which will require latex to be used. I have done concrete porches b4 , just thinned down 1st coat and full strength 2nd coat, worked fine with Tough Shield Floor & Patio,
But the cheap way, a five of L*wes Exterior semigloss would be fine or no?
The color will be white or off white
Do I need to use a primer or should I just sprayaway?
I said we could just paint it cheap but maybe in 5 years it might peel away or chip
And for the fiberglass doors is there a special primer I need to use?
Thanx
Robert
Robert Good
It's Your Life-Make Fun Of It!
http://www.robertgoodpainting.com
GoodPainter is offline
Old 12-03-2006, 01:59 PM   #2
Painting Contractor
JMGP's Avatar
Re: Interior Garage Concrete Block
I would solve the "Moisture" issue FIRST! If there is a moisture issue... your paint will "peel away" a lot sooner than 5-years...
I would use Benmoore's "Block Filler"...M88
They also have a water proof masonry coating... M89
You dont need primer on the fiberglass door... just a quality "latex" paint....
JMGP is offline
Old 12-03-2006, 02:57 PM   #3
Professional Painter
Richard's Avatar
Trade: Owner/Operator
No one has been able to show me a better product than SW's "loxon". Get that and you wont be sorry...
All your talk about cost goes in one ear and out the other...
--do it right, or the job will end up costing much more very soon thereafter.
By the way, if you keep considering using Lowes or Home Depot paints, you might have to change your name from "goodpainter" to something much less desirable
Rich
Richard is offline
Old 12-03-2006, 03:11 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
I'm not painting anything five times to get a good finish
IMO that's not cheap, I've got other things I'd like to be doing
IMO my time is worth something
...well, now wait up
Yeah I do put 5 coats total on some stuff
But that's some high end painting projects and I'm getting paid to put 5 coats on it
I'll re-phrase:
I'm not putting 5 coats of cheap paint on concrete when 2 coats of decent stuff will do
Signature Quote
slickshift is offline
Old 12-03-2006, 03:13 PM   #5
Richard's Avatar
I'll re-phrase:
damn skippy!
Rich
Richard is offline
Old 12-03-2006, 03:22 PM   #6
I dont USE cheapo but My friend wont buy good paint
I guess I could tell him I wont paint it unless he uses "my" paint
BTW I am doing this @ no cost to him
I choose not to use SW, do you no a comparable in BMoore?
Thanx
Robert
Robert Good
Old 12-03-2006, 03:27 PM   #7
Richard's Avatar
Moorcraft Super Spec® Latex Vapor Barrier Primer Sealer 260 looks good--never used it though
Rich
Richard is offline
Old 12-03-2006, 04:29 PM   #8
lmcgrew79's Avatar
Trade: Painter
Send a message via AIM to lmcgrew79 Send a message via Yahoo to lmcgrew79
May sure you have a large enough pump to spray the block filler, like 1095 or larger, or you could burn you pump up. I agree with the one above, loxon block surfacer is the way to go.
lmcgrew79 is offline
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
Concrete Block Wall skpjose Construction 26 10-20-2008 04:38 AM
Installing Hardie Siding over Concrete Block? Chrome Toaster Remodeling 1 02-28-2007 12:07 AM
Anchor size for concrete block. Chris G Carpentry 3 12-06-2006 04:42 AM
Concrete block brickledge on ICF stemwall gregj Masonry 3 09-29-2006 10:07 AM
