Indoor Residential Trim Spraying
Old 10-06-2009, 09:07 PM   #1
Droosky's Avatar
Trade: Residential Painter
Should I spray or brush interior trim in an occupied home? I currently use my brush and sometimes a small roller . I have a Fuji HVLP and want to know if the prep work is worth the potential risk of property damage? Will I save much time?
Droosky is offline
Old 10-06-2009, 11:03 PM   #2
Metro M & L's Avatar
Trade: Painting & Flooring
Re: Indoor Residential Trim Spraying
I have never done hvlp, only airless. I would not do it. Especially with hvlp; my understanding is the mist can land across the room from where you are spraying. I only spray with airless in unoccupied areas.
Maybe if the finish had to be perfect and the budget supported it you could get some zip walls and tent off the area you're working in and go area by area; but then you're not saving time your just improving the finish. Like if you had a bunch of high end windows to do.
"Yeah... It's worthy of a sig quote."
Metro M & L is offline
Old 10-07-2009, 07:24 AM   #3
Droosky's Avatar
I kinda figure this but wanted to see if someone could talk me into because it might've been safer than I was thinking. Thanks for making the choice simple for me...I will not do it.
Droosky is offline
spraying trim eric wayne Painting & Finish Work 7 06-05-2009 11:08 PM
Questions about interior trim spraying Jerdog44 Painting & Finish Work 13 08-23-2007 04:39 PM
spraying Trim Workaholic Painting & Finish Work 7 03-08-2007 12:26 AM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 08:49 AM
