Trade: GC / Owner Builder
If Using SW, Which Specific Product For Walls, Ceiling And Bathrooms?
I'm having a beach home built on coastal NC. Interior Paint is scheduled to start in 4 weeks. Builder is pressing me for colors and paint choice. This is an area where the only professional paint store is Sherwin Willaims, so guess what I'll be using?
OK, so if I prefer a very flat / matte sheen, but would also like super durability. Some of the new washable flats come to mind. Also, this home will see heavy rental duty in the summer from vacationers, so something that will withstand wear and tear in the main living areas as well as heavy moisture from showers in the bathrooms. So, I'm looking for recommendation on specific SW products for: Primer (I hear SW Primer is awful, if so can you suggest an alternative?) Ceiling Paint (SuperPaint vs Cashmere?) Walls (SuperPaint vs Cashemere?) Bathrroms (Bath Paint?? vs Cashmere?, etc.), Btw, I DON't want something to shiney in terms of the sheen on the finish. Thanks in advance for any help you can provide! Sincerely, Bradesp |
Back from the dead...
Trade: Paperhanger/Painter
Re: If Using SW, Which Specific Product For Walls, Ceiling And Bathrooms?
Primer = yeah, Preprite sucks, I use Ben Moore Fresh Start
Ceilings = Superpaint Walls = Duration Bathrooms = Duration + mildew inhibitor OR Zinsser Perma-White Cashmere is good too, if you don't want to pay the steep price of Duration. Last edited by ProWallGuy; 01-08-2006 at 09:39 PM. |
Blue Star
Trade: Painter
SW makes a bathroom specific paint and this is strongly recommended
especially if is going to be a partial rental. This preferred paint will stand up to the moisture and humidity it will be receiving and is easy to keep clean. As far as the common areas stay away from the cashmere and stay with the easy up keep. It is much easier to clean the walls than repaint. As far as ceilings go, basic ceiling paint, Acrylic Latex (Flat) will do the job every time. |
Blue Star
Trade: Painter
Fresh start is the preferred prime for a lot of applications, but if SW is the only availability in that area then your choices are limited.
I prefer Ben Moore to anything myself. Stay away from The "Depot" Home that is. |
Blue Star
Trade: Painter
ProWall Guy
Reviewing these posts over the past couple hours you appear to be a constant source of great information. Question?? I am in the middle of a new const. and the elec. is not scheduled for 10-14 more days, and I am anxious to keep chugging alon here. I have been using propane high hat heaters, but at this point the homeowner has gone through 200lbs. of propane, and I feel he is wasting his money at this point. Is it safe enough to paint between 35-45 degrees and expect the paint NOT to change as it dries as it did when we had the heat going? |
#6 | |
...jammin
Trade: Rock Disciple
Re: If Using SW, Which Specific Product For Walls, Ceiling And Bathrooms?Quote:
But in general you'd be pushing it with most of them I don't know of any off-hand that I'd do that with Most interior paint should be 50*+ overnight Maybe if it dropped below that at night you'd be OK But you should really start a new thread with the temp Q in the title, you'll get a wider variety of answers that way Maybe someone will know of an interior paint you can use @ 35*-45* |
It won't change as it dries, it just plain won't dry at those temps.
It will most likely dry to the touch, but the curing of it would take way too long, and temps like those changing from night to day will slow it down even more. I think it would effect the bond to the wall at the tape lines. I probably wouldn't even think of priming until it was a steady 50 degrees or so. |
Blue Star
Trade: Painter
I am just at the home stretch with the secong coad on the trim work(post installation) and touching up walls that have been modified by the homeowners. It kills me that still there is no power at the house.
This job was quoted for July/August. I will probably loose a couple bills at this point. However the same builder gave me another house just down the road. I will not even start this one until there is heat and power. |
Blue Star
Trade: Painter
Propane heaters are good for short term but nothing to heat a whole house on.
#10 | |
...jammin
Water, heat, power, these are all in my contracts.
#12 | |
You didn't recommend the SW Bath Paint for the bathrooms, but instead indicate the Duration / Zinsser Perma-WHite combo. What does this mean? Are you suggesting Zinsser as the primer, then cover with the duration? Also, these bathroms (5 of them) will frequently see HEAVY service in the summer. It wont be uncommon for the bathrooms to see 4-5 showers EACH. Lots of steam showers. I've got oversized ventilation, but if renters are in the house, who knows if they'll turn the light swith on :-( So, given this scenario, would you change your recommendation on bath paint? Also, do you agree about the quality of SW primers? If so, what you would recommend as an alternative? Thanks!!! bradesp |
#13 | |||
| Lots of questions about drywall and bathrooms | nobody | Drywall | 30 | 11-27-2008 01:33 PM |
| Drop ceiling | Tonkadad | Remodeling | 4 | 02-13-2007 11:18 PM |
