HVLP Turbine Or Conversion Gun? - Painting & Finish Work - Contractor Talk
Old 10-06-2010, 10:24 AM   #1
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
I have a small cabinet finishing job coming up which requires a lacquer over a NGR dye. I want to spray the doors in my shop but need to upgrade from the POS gun I have now.
I don't get into refinishing often but want to get a fine finish on these doors and want something to take on more of these jobs when they come along.
I'm pretty sure I can do it but want to get opinions on wether I should look into a non bleeder conversion gun or a turbine. I already have the compressor with separators in my shop and also have a small portable compressor if I needed to do small on-site stuff.
Here is the gun I was considering, Wagner softspray conversion gun
As far as turbine systems, I have no idea. I was thinking of either the Graco 3900 or the Wagner Control Spray +. They seem cheap though. Remember, I don't do this often (maybe 1 or 2 times a year) but I would like to be able to offer it occasionally on smaller stuff.
bert0168 is offline
Old 10-06-2010, 05:55 PM   #2
Money Changer
bert0168's Avatar
Re: HVLP Turbine Or Conversion Gun?
What, 31 views and nobody has an opinion?
bert0168 is offline
Old 10-06-2010, 07:38 PM   #3
Steve Richards's Avatar
Trade: hack painting
I only have airless.
Would you rather have no advice, or crappy advice?
Steve Richards is offline
Old 10-06-2010, 07:38 PM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,783
That's because finishing is not a subject most guys will know about on a contracting forum.
I know a lot about the subject.
What is it you would like to know?
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 10-06-2010, 09:09 PM   #5
Money Changer
bert0168's Avatar
Leo,
PM sent
bert0168 is offline
Old 10-07-2010, 04:48 PM   #6
briancreary's Avatar
Rewards Points: 75
I have used a 212 tip with the pressure turned way down in my Graco. This provides mixed results depending on what product you are using. I would go the HVLP route. HVLP is a little finer and if you sand in between coats you can control the final outcome better.
What product are you spraying?
briancreary is offline
Old 10-08-2010, 04:53 PM   #7
Gough's Avatar
Trade: painting
I use an older Titan turbine system with Graco HVLP guns. Mostly, I use it for entry doors, and the 1-Qt siphon pot works fine. When we've got a house full of trim and doors, I switch it over to a pressure pot system. I like the turbine system for it's flexibility and portability. It's handy when I have to go on a job and spray one 12-inch sidelight, for instance. Jobs like that make me glad that I don't have to drag around a compressor.
We've used this system for water-borne polyurethane, pre-catalysed lacquer, alkyd enamel, and aniline dyes.
Gough is offline
hvlp turbine jchomes Painting & Finish Work 0 03-21-2010 09:58 PM
Hvlp platinumLLC Painting & Finish Work 9 02-12-2009 10:20 AM
Air Compressor or Turbine for HVLP? Rob Vinnedge Painting & Finish Work 5 11-05-2008 04:20 PM
Turbine HVLP sprayers anyone? BMAN Painting & Finish Work 3 11-12-2006 05:31 PM
Hvlp Turbine Paint Spray Systems MIMI Painting & Finish Work 3 03-24-2006 07:06 AM
