How To Paint A Non Paintable Silicone?
Old 12-04-2010, 11:15 PM   #1
bestjetpilot's Avatar
Trade: Alex Stucco
How to paint a non-paintable silicone I have done the same mistake and didn't realize until i try to paint. But a little of brain movement give me a bright idea, and i did paint successfully all trims around bath tub, and paint stays on it okay. Just in case you did same mistake that i did, used non paintable silicone and try to paint. Don't worry, you will paint too, and paint will stay on it. You don't need to scrape old silicone or use paintable silicone over non paintable silicone, or any thinner. ALL YOU NEED! IT'S A REGULAR HAIR DRYER BLOWER. PUTT THEM ON HIGH HEAT AND GO! First apply a thick and even layer of paint on surface you painting, and apply heat before paint gets off of the silicone, and there you go, the way to SUCCESS!!! Or try to paint and use at the same time hair dryer. Hold hair dryer about 10 inches away, AND ON HIGH HEAT. But do not over paint, other way you'll have to scrape the paint, and make it even worse. You can re-paint with roller when it's completely dry, but the first time you have to paint with paint brush. And good luck!!! And if you have any questions, ask at. bestjetpilot@hotmail.com
Added by: Aleksandr Dovgalets.
bestjetpilot is offline
Old 12-05-2010, 02:23 AM   #2
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,352
Re: How To Paint A Non Paintable Silicone?
Not one time in my entire career have I put a non paintable caulk where I needed paint.
SuperiorHIP is online now
Old 12-05-2010, 09:00 AM   #3
Steve Richards's Avatar
Trade: hack painting
Originally Posted by bestjetpilot View Post
How to paint a non paintable silicone I have done the same misstake and didn't realise until i try to pait. But a little of brain movement give me a bright idea, and i did paint successfuly all trims around bath tub, and paint stays on it okay. Just in case you did same misstake that i did, used non paintable silicone and try to paint. Don't wory, you will paint too, and paint will stays on it. You don't need to srape old silicone or use painable silicone over non paintable silicone, or any thiners. ALL YOU NEED! IT'S A REGULAR HAIR DRYER BLOWER. PUTT THEM ON HIGH HEAT AND GO! First apply a thick and and even layer of paint on surface you painting, and apply heat before paint get's off of the silicone, and there you go, the way to SUCCESS!!! Or try to paint and use at the same time hair dryer. Hold hair dryer about 10 inches away, AND ON HIGH HEAT. But do not over paint, other way you'll have to scrape the paint, and make it even worse. You can re-paint with roller when it's completly dry, but the first time you have to paint with paint brush. And good luck!!! And if you have any questions, ask at. bestjetpilot@hotmail.com
hmmm..sounds like a pretty neat trick. Maybe I'll try it someday.
BTW
another neat trick....spellcheck!
Steve Richards is offline
Old 12-05-2010, 09:06 AM   #4
stp57's Avatar
Trade: carpenter/ handyman
Rewards Points: 1,000
I have seen good primer fall right off of that stuff. I have no idea what will ever stick to that stuff? Good luck.
Steve
stp57 is offline
Old 12-05-2010, 09:09 AM   #5
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 11,545
I have seen lots of HO put that stuff on areas that needed to be painted later.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-05-2010, 09:19 AM   #6
I THINK the idea is to have the hair dryer make the paint dry before it can separate.
How it would hold up, I have no idea. (but I suspect not very well)
I normally just remove it.
Kitchen back-splash is where I run into it most often. Sometimes I'll mask off the counter, and spray-can-coverstain it.
If it has to be silicone... best to remove it, paint, and re-caulk w/clear.
Old 12-05-2010, 09:32 AM   #7
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
I'd remove it too. Any efforts made to rig this are going to be time wasted.
Remodelor is offline
Old 12-05-2010, 09:36 AM   #8
Job last year, guy had used white silicone on every seam of his bead-board paneling...and he had a LOT of paneling/wainscot.
I removed all of it, re-caulked, and painted
I also caulked his bathtub for him (w/silicone).
When I left, I gave him the remainder of the tube, and made a joke about him not trying to use it on his walls.
He was a pretty good sport about it.
Old 12-05-2010, 11:26 AM   #9
Trade: Alex Stucco
Looks like you guys have to try paint over a not paintable silicone before argue, and then you can answer. Steve Richard have catches the idea all ready. The thing is. If paint stick to silicone while you painting, then what making you think, they won't stay after it will dry? Of corse it won’t stay if you try to scratch, but for normal use it will stay perfect and even. The whole idea is to boost the dry time, I’ll show you pictures of the silicone, and the molding i painted, but later. This idea will work on seams, not wide areas. But I did have wide area covered with silicone about ĺ of the inch, and I did pained okay.
Old 12-05-2010, 11:36 AM   #10
ok
Lookin' forward to it.
Old 12-05-2010, 11:37 AM   #11
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,205
I've ran into this a couple of times on jobs where the HO has used silicone caulk.
They didn't want to pay me to remove and recaulk.
So, what I did was just caulk over it with a paintable caulk. Then paint over that. Worked fine.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 20,000 Subscribers and over 5,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
thom (12-11-2010)
Old 12-05-2010, 11:45 AM   #12
Looks like you guys have to try paint over a not paintable silicone before argue, and then you can answer. Steve Richard have catches the idea all ready. The thing is. If paint stick to silicone while you painting, then what making you think, they won't stay after it will dry? Of corse it wonít stay if you try to scratch, but for normal use it will stay perfect and even. The whole idea is to boost the dry time, Iíll show you pictures of the silicone, and the molding i painted, but later. This idea will work on seams, not wide areas. But I did have wide area covered with silicone about ĺ of the inch, and I did pained okay.
BTW
If bestjetpilot's driving the plane...I'm stayin' home.
The Following 2 Users Say Thank You to Steve Richards For This Useful Post:
pinwheel (12-05-2010), stp57 (12-05-2010)
Old 12-05-2010, 12:04 PM   #13
..and before I get band for that...
BJP I suggest that you try to calm down.
I know you're excited to be typing to us...that's certainly understandable.
Take time to read what you've typed before you hit the post button.
That's what I do. (But sometimes I hit the post button anyhow).
Old 12-05-2010, 12:22 PM   #14
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
....all your doing is making it so the film drys as your lay it down. It will NEVER stick to the silicone and WILL fail. It may cover now...but it will just fall off. This is not the correct way to go about this.
TBFGhost is offline
Old 12-05-2010, 01:13 PM   #15
plazaman's Avatar
Rewards Points: 1,202
bonding primer then paint
plazaman is online now
Old 12-05-2010, 04:58 PM   #16
Finish Carpenter
TBFGhost's Avatar
still won't stick.
TBFGhost is offline
The Following 2 Users Say Thank You to TBFGhost For This Useful Post:
pinwheel (12-05-2010), Remodelor (12-05-2010)
Old 12-05-2010, 05:27 PM   #17
It will unless you try to scratch it.
(that's what BJP says anyhow)
Old 12-05-2010, 06:36 PM   #18
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
If non-paintable silicone can be painted, does it not invalidate the term "non-paintable"?
Non-paintable silicone is exactly that, non-paintable.
loneframer is offline
The Following 2 Users Say Thank You to loneframer For This Useful Post:
Remodelor (12-05-2010), stp57 (12-05-2010)
Old 12-05-2010, 09:56 PM   #19
Workaholic's Avatar
Trade: Painting Contractor
BJP sure is excited to tell us his idea on this subject, he brought another thread back to life with a almost 4yr old OP http://www.contractortalk.com/f8/pai...ilicone-15936/ only to post the exact same post.
Sean
Workaholic is offline
Old 12-05-2010, 11:46 PM   #20
Trade: Alex Stucco
Originally Posted by Steve Richards View Post
BTW
Ha-ha. I bet you did fly couple times with me, I was your pilot on 737-300, 400 and bigger planes.
Paint or stick with solid color stain? JL1 Painting & Finish Work 46 01-16-2014 05:58 AM
Paint Shaver vs Infrared Paint Removers Goochie Painting & Finish Work 12 09-11-2012 04:05 PM
Aura Paint Review (Matte Finish) DeanV Painting & Finish Work 43 05-06-2010 08:45 PM
Independent Paint Review? KPSquared Painting & Finish Work 11 04-01-2010 08:23 AM
cabinet paint of choice world llc Finish Carpentry 8 12-31-2008 07:43 PM
