How Often Should I Change My Tip?
Old 11-16-2008, 05:20 PM   #1
renet's Avatar
Trade: Painting Contractor, Siding Contractor, Custom Home Builder
What are opinions out there of how often to change the spray tip?
Do you wait till it begins to "finger" or are you proactive and change it before than?
Do you count how many gallons the tip has sprayed?
Do you change it before each job?
I realize it will also vary per type of material being sprayed.
For example:
Exterior Satin - how many gallons before changing tip?
renet is offline
Old 11-16-2008, 05:24 PM   #2
mdshunk's Avatar
Re: How Often Should I Change My Tip?
Originally Posted by renet View Post
How often should I change my tip?
As often as the doctor says to. Good hygiene will allow your tip to last longer.
mdshunk is offline
Old 11-16-2008, 05:30 PM   #3
Professional Instigator
rbsremodeling's Avatar
For example:
I change mime every 30 days or immediately after spraying elastomeric or water proofing paint
rbsremodeling is offline
Old 11-16-2008, 05:50 PM   #4
Handle It!
MALCO.New.York's Avatar
It also dependent upon where ones tip has been. Yes?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 11-16-2008, 08:26 PM   #5
plazaman's Avatar
i havent changed any yet, and sprayed over 200 gallons with them (set of 4) what am i missing out ?
plazaman is offline
Old 11-16-2008, 08:27 PM   #6
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
I heard of some who change it every time they are done.
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 11-16-2008, 08:34 PM   #7
Handle It!
If you want a PERFECT spray pattern and do not wish for the possible hassle of one crapping out in the midst, build the price of a New Tip into EVERY job and do a change out EVERY time. Fairly simple. "Cost of doing Business".
I imagine that a tip is considered a "Consumable" in the business of Paintin'.
Old 11-16-2008, 08:39 PM   #8
I spray most of my remodels. with as little rolling as possible. Clean tip nice finish no need to back roll
Old 11-16-2008, 09:51 PM   #9
RCPainting's Avatar
Trade: Painting in Utah
Yep, I may use several in one job.
"Fingering" usually means a pressure problem. You will see a decrease in fan size, yet same amount of paint going out when a tip is wearing out. So you are using more material to cover smaller area.
Most tips are rated for 40 gallons.
RCPainting is offline
Old 11-17-2008, 01:59 PM   #10
Traditions2's Avatar
Trade: painting and refinishing
I was going to say about 100 gallons. When I am spraying primer and backrolling I use old tips. Finish isn't too important. Just getting it on the wall and then backroll. For a fine finish a worn out tip is bad joo joo.
Traditions2 is offline
Old 11-17-2008, 06:29 PM   #11
Workaholic's Avatar
For FF trim tips i change them out at about 40 gallons, sometimes a little sooner and turn them into primer tips.
For ceiling tips i change them when they need to be changed. I can get 100 - 200 gallons of spraying flat ceiling paint.
Sean
Workaholic is offline
Old 11-17-2008, 06:55 PM   #12
A bit abrasive.
WisePainter's Avatar
When it "sounds" different.
A new tip has a louder high pitched hiss, a worn out tip is quieter and duller.
Seriously.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 11-17-2008, 07:38 PM   #13
General Contractor
Snow Man's Avatar
Trade: Construction Management
Did you ever hear of a self cleaning tip?
why didnt that come up around the 2-3 post??
Do I have to solve all the painting solutions round here?
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 11-17-2008, 09:13 PM   #14
Handle It!
No such thing. It exists, but does NOT live up to its name. I know this and I am NOT a Painter!
Old 11-19-2008, 08:41 AM   #15
premierpainter's Avatar
A good tip can last longer than 40 gallons. We use a tip (427)for a heavy coating and it lasts 200 gallons prior to seeing the fan look. Yes you can build it into the cost of a job, but they last longer than most people think. Keep em clean and they will last longer too.
premierpainter is offline
Old 11-19-2008, 10:42 AM   #16
General Contractor
Snow Man's Avatar
Before you stick your foot or any other body part in your mouth ....research it.
610 457-9721
Snow Man is offline
Old 11-19-2008, 10:45 AM   #17
Handle It!
NOTHING is "Self Cleaning". PERIOD.
So I suppose that you can buy one and NEVER buy another. EVER!
Old 11-19-2008, 05:17 PM   #18
General Contractor
Snow Man's Avatar
They last a very long time champ.
Especially if you take care of your equipment .
lmao again
610 457-9721
Snow Man is offline
Old 11-19-2008, 05:27 PM   #19
Handle It!
And yet.....5 FULL TIME painters here who have answered this thread have YET TO mention this device nor chime in and agree with you.
I think it may be time for you to start your own PAINTING PRO Board. After all, you know more than the PROS that DO NOT Plow!
I still Love Ya Brother!
Old 11-19-2008, 06:21 PM   #20
A bit abrasive.
you two sound married.
That is a RAC X reversible tip for when a booger gets through the rock catcher and then the gun filter.
Turn it, a quick pull on the trigger, flip it back around and get back to work.
"I don't want to see a bunch of spatters around the exterior of a house, and if the spatter is too large you will owe me for the wasted paint!!!"
old guy I worked for way back in the day
Tags
spray tip
Change Order fees for Residential General Contractors?? SBI Business 6 09-29-2008 04:09 PM
home office deduction rules change... orson Business 6 08-20-2008 07:07 PM
Box Change Out Pricing A+Carpenter Electrical 42 10-17-2007 05:04 PM
Cost plus change orders Q mdshunk Business 5 11-04-2006 09:37 PM
