Trade: Carpenter/Cabinetmaker
How Much Can You Thin Latex?
Like the question says, how much? I just built a custom mail/light post with Azek trim boards. Azek recommends usin a latex top coat. I have a Titan airless sprayer which would not require thinning, but there are some tight/intricate spots to spray on the post. I would probably just make a mess using the airless. I also have a 3-stage HVLP sprayer which has great control, and I usually spray oil with it, thinning it down to about 22-28 seconds throught a viscosity cup. Can I thin latex down that much without ruining the paints properties? Thanks
Trade: Paint
Re: How Much Can You Thin Latex?
That is quite a bit of thinning. What kind of HVLP do you have? The best scenario is changing out your needle and cap. Most HVLP's come with a #3 cap and needle. To spray latex you would need to use a #5 cap and needle. You may need to thin slightly to push through. If you have a CS9100 or a ProComp 4900, you should have no problems.
#3 | |
Professional Tradesman
Re: How Much Can You Thin Latex?Quote:
Well, I've been doing some research, and I might be buying a Fuji Q4 HVLP system. I want to get into finishing my own projects instead of sending them out, so this looks to be a quality unit with great versitility. The airless is great for latex, but I end up with wasting alot for paint for just doing small projects. After all, it takes nearly half a gallon to prime the pump and the hose with paint. Thanks
Don't forget HVLP is incredibly slower compared to airless. I have a HVLP 4 stage turbine CS9100--used it a couple of times. It just does not pay off using it for my job specifics (mostly new construction and exterior repaints)...I can go almost as fast with the brush after a couple of redbulls..lol..
Kashmir :Thumbs: |
BTW i thin my oil paints 5%. i was told so by many reps for SW and Titan---guess it is safe to assume something similar for latex
Kashmir :Thumbs: |
| How much do you thin your latex paint? | steve-in-kville | Painting & Finish Work | 65 | 10-30-2011 02:25 PM |
| why is latex paint peeling?? | Zeebo | Painting & Finish Work | 24 | 05-28-2009 07:59 AM |
| latex semi gloss over oil semi gloss - can it be done? | Zeebo | Painting & Finish Work | 13 | 09-05-2007 06:38 PM |
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Determining if latex or oil base paint | gary lee | Painting & Finish Work | 6 | 07-31-2007 01:02 AM |
