How Many Coats With Tinted Primers?
Old 05-24-2006, 01:26 PM   #1
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
If I use a tinted primer can I use only 1 coat of paint and still get a nice paint job without compromises?
The conditions would be painting over a white wall with some drywall patching, the final color would be a beige and the paints would be Benjamin Moore.
Mike Finley is offline
Old 05-24-2006, 01:43 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: How Many Coats With Tinted Primers?
Mike, if its flat paint, and from a good quality manufacturer, it should be no problem for it to fly with one coat from white to beige.
However, if it has a sheen of any kind, satin, eggshell, pearl, semi-, etc., almost always you will need 2 coats of finish to make the sheen appear even.
ProWallGuy is offline
Old 05-24-2006, 04:35 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
It's a compromise
But you may be able to get away with one coat of flat premium BM over tinted primer
Both primer and top coat will have to go a little slower to ensure even coverage
You can out the good BM on pretty thick
...I could make it look good...yeah. no problem
slickshift is offline
Old 05-24-2006, 05:00 PM   #4
Zeebo's Avatar
Trade: Painter
Mike...I have done this before on commercial jobs and some private homes. I don't like doing this, but the customer is fully aware of what I am doing. I do not offer a warranty for this type of application as 2 coats of paint is required to get my warranty (not primer and paint). Usually, the customer has a certain budget and this is one alternative that I suggest.
I have had success with off whites and beiges. I have had great success on priming drywall (tinted primer) follow by 1 coat of paint. I usally have the primer tinted 80-90%. Yes I know it's high, and I run the risk of it being darker than the actual paint, but it has worked for me.
In other words, yes it does work, and yes it does create a good look and finish....however, the customer is given full disclosure and signs off on this fact in the contract.
The point about the different kinds of sheen is something I have never considered as I have always done this with a flat sheen.
Zeebo
Zeebo is offline
Old 05-24-2006, 05:05 PM   #5
phinsher's Avatar
Trade: Paint and wallpaper
Its possible, but there are compromises.
As with all my answers it just depends. If your customer isn't the pickiest, or if they just wont pay for 2 coats then go for it. If you're about to paint a million dollar home than I wouldn't try it.
phinsher is offline
Old 05-24-2006, 10:29 PM   #6
rocknroller
cutnroller's Avatar
Trade: Residential/Commercial Painting
Send a message via MSN to cutnroller
You mentioned some drywall patching.... if you go around and hit those spots first with a fairly dry roller and feather it out well and let it set up before you do the primer coat, you won't see them once you put the top coat on. As mentioned though, only for desperate circumstances when you can't put two real coats on.
cutnroller is offline
Old 05-24-2006, 11:52 PM   #7
Chief Toilet Mover
Curse you professional painters... I thought I was onto something... back to the drawing board.
Old 05-25-2006, 07:47 AM   #8
...jammin
slickshift's Avatar
Hey wait a minute, aren't you the guy that said the best way to paint window panes was to remove the glass and dip them?
Old 05-25-2006, 08:45 AM   #9
Chief Toilet Mover
Not good?
Son of a!!!!
I'm never going to catch that damn road runner!
2 coats or one coat saucedo80 Painting & Finish Work 38 03-02-2007 08:23 PM
Am I outrageous? AAPaint Painting & Finish Work 39 02-16-2007 12:58 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
sanding between coats GoodPainter Painting & Finish Work 9 09-12-2006 12:09 AM
