How To Get Paint Off Of A Cement Floor That Has A Stain Finish
Old 03-05-2006, 10:55 PM   #1
dfwhomeremodele's Avatar
Lightbulb
My painter got oil based paint on my customers cement floor that has a stain finish on the floor. The stain finish is coming off from us trying to remove the paint. Any thoughts or ideas on how to remove this without further damaging the stained concrete would be greatly appriecated.
dfwhomeremodele is offline
Old 03-05-2006, 10:57 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: How To Get Paint Off Of A Cement Floor That Has A Stain Finish
What type of paint was spilled, oil or latex?
How long has it been there?
What type of stain is on the concrete?
ProWallGuy is offline
Old 03-05-2006, 11:07 PM   #3
The paint is a oil based
Old 03-05-2006, 11:09 PM   #4
It has been there about 4 days
I do not know what kind of stain finish is on the floor
Old 03-05-2006, 11:18 PM   #5
ProWallGuy's Avatar
That is a problem. I would try a q-tip dipped in either mineral spirits/paint thinner, or maybe lacquer thinner if it acts stubborn. Then be prepared to match the stain and apply a coat to those areas.
Old 03-05-2006, 11:37 PM   #6
Thanks for your help, I will try that
Old 03-06-2006, 12:00 AM   #7
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
You could also try a small wire brush if it has hardened up, but again, be prepared to match the stain...Try just scrubbing the spot and nothing else...it may pop right off if you're lucky. Is the concrete smooth?
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 03-06-2006, 12:48 PM   #8
rocknroller
cutnroller's Avatar
Trade: Residential/Commercial Painting
Send a message via MSN to cutnroller
I wonder if heat might work? If the old surface is cured well and the new isnt, they may separate nicely, especially if the old surface is smooth. Note: havn't actually tried this myself in this exact same situation so just a thought.
cutnroller is offline
Old 03-06-2006, 08:12 PM   #9
1Painter's Avatar
Trade: House Painter
Try a straigt edge razor blade get off much as you can, then maybe a Q-tip with goof off and clean rag. Hope it's not a large area.
1Painter is offline
Concrete paint or stain? cjc Painting & Finish Work 4 08-06-2007 10:12 PM
Paint or Stain on Cedar? North Dakota Painting & Finish Work 9 08-03-2007 06:56 AM
French door paint and stain Luke's Dad Painting & Finish Work 6 02-23-2006 09:57 AM
Oil Based Paint leaving wrinkly finish on doors dwbrooks Painting & Finish Work 8 11-09-2005 11:29 PM
