How To Clean A Clogged Airless Sprayer
Old 09-04-2008, 02:08 PM   #1
cmansmith's Avatar
Trade: Framer, Carpenter
I found a airless Campbell Hausfield Paint Sprayer on craigs list, all I know about it at the moment is that it is clogged. I assume that means the last time it was used it didn't get cleaned. The guy only wants 75 dollars for it. imagine the worst case scenario... Is it worth it? Can it be cleaned? Any tips would be greatly appreciated. I am a framing carpenter. I have never used a sprayer before. I need to paint a rental house inside and out.
cmansmith is offline
Old 09-04-2008, 02:51 PM   #2
VoodooSteamBoat's Avatar
Trade: Painter/Landscaper
Re: How To Clean A Clogged Airless Sprayer
sounds too good to be true.. no real painter wouldn't take half an hour to clean it out, if they could increase the value of there sale by a hundreds of dollars. sounds fishy to me
VoodooSteamBoat is offline
Old 09-04-2008, 04:16 PM   #3
cmansmith's Avatar
It's not a painter, it's a home owner. He used it to paint his house and thats it. I don't know if he bought it new or what but judging by the area he lives in I doubt he cares about a hundred bucks, probably just wants to get rid of it. That being said do you think its salvageable assuming that its in bad shape but still runs?
Old 09-04-2008, 05:21 PM   #4
Handle It!
MALCO.New.York's Avatar
Lots O'Luck!!!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-04-2008, 08:13 PM   #5
boman47k's Avatar
I sold one for $40 once. I had never used one and it stopped up bad. Used very little and was given to me. I think it was about an $800 sprayer. I'm thinking it was....a Graco? Hell might have been a Titan. 3 or 4 years ago
boman47k is offline
Old 09-04-2008, 08:17 PM   #6
painterman's Avatar
Trade: Historic Restorations
The CH web site might be able to help or call their help line. They have techs that can walk you through it. What model is it.
painterman is offline
Old 09-04-2008, 08:30 PM   #7
General Contractor
Snow Man's Avatar
Trade: Construction Management
Each airless sprayer must be treated with kid gloves , meaning you must flush the unit after each use. furthermore , after cleaning you must prime the unit with a "throat sealer" or trans fluid so that the suction ball AND THE PACKINGS stays lubed for the next use.. Try removing the suction tube from the unit and stick a screw driver up it's throat and replace hose and try to suck water first .................IF that dont do the trick , send it to a spray unit repair shop for new packings ....usually appro. $75.00-$175.00 depending on size of unit!:whis tling
Signed "THE king of spray"
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 09-05-2008, 03:40 PM   #8
NAV's Avatar
Trade: commercial building restoration
don't buy it. i had my guys go to lunch and they left a two component epoxy in the pump. its a boat anchor now.
plus the pump you described is a piece of crap anyway.
NAV is offline
Old 09-06-2008, 07:50 AM   #9
boman47k's Avatar
Just thought I would clarify this statement, I did not stop it up. It was that way when I got it. It was given to me because it was stopped up.
boman47k is offline
Old 09-10-2008, 12:46 AM   #10
cmansmith's Avatar
thanks for the replies i went to look at it and it was a piece o crap. It looked like it had been sitting outside for about six years. I told the guy he could pay me 75 dollars to haul it off. He declined my offer.
Using an airless sprayer - anyone out there that self taught / learned themselves? Zeebo Painting & Finish Work 14 01-30-2008 03:05 PM
Graco / Magnum XR7 Airless Paint Sprayer $285 ATLT Contractor Swap 0 11-27-2007 10:03 AM
airless sprayer and generator gary lee Painting & Finish Work 14 05-11-2007 08:11 AM
Airless sprayer DROPLETS Kashmir Painting & Finish Work 11 01-07-2007 07:45 PM
Gummed up airless paint sprayer. JustaFramer Tools & Equipment 0 11-27-2005 07:49 PM
