Property Manager
Trade: Drywall/Textures/Paint
How To Avoid "framing"?
When its brush and roller in a residential new construction or repaint, what is your process for avoiding the dreaded "framing" look? (when you brush the corners and then roll the walls... the brushed paint stands out around the rolled portion of the walls, thus causing a "framed" look... in case you were not familar with this term)
I've been trying various techniques and some work way better than others. What's your technique for interior walls? steve |
Professional Painter
Trade: Owner/Operator
Re: How To Avoid "framing"?
The term is "picture framing"....and it is avoided by painting quickly and always keeping a "wet edge" of paint. You have to paint fast and when you are dealing with eggshell, satin and semi-gloss it's even MORE important to go fast.
Arent you painting 2 coats(at least)?...this should take care of any picture framing you are encountering because usually it happens on the first coat To avoid this(or cut down on it from happening)if your walls are big, use an 18" roller to double your speed, also when you cut your walls to the ceiling, MAKE SURE when you do the initial cut, you go right back over what you cut with a good slab of paint(backbrushing or crossbrushing, etc.) and make sure when you are rolling, to roll as close to every edge as you can...I usually leave about 1"........ OH....the most important thing is good paint....hope you're using some!: |
Property Manager
Most, if not all, of my paint jobs get two coats (or more)... unless its a repaint and then we use something close to the color being covered.
In many cases I hit the corners again while the paint is still semi-wet... leaves a heavy coat. Most of time this works, but there are times that I can see where the rolling stopped and the brush started. Maybe my cutting technique needs refinement?? Maybe I'm being too hard on myself?? BTW- I use mostly SW paint. Occassionaly other brands as the job dictates. steve
Is it possible that your brush or your roller cover are such crap, that they leave a great disparity in finish texture when compared?
#5 | |
...jammin
Trade: Rock Disciple
More likely your rolling technique
Also you should be cutting then rolling one wall at a time (wet edge) Cheaper, darker, and shinier paints show it more ...and mdshunk has an excellent point, the tools can make a great difference Although SW makes some great paints, they also make some of the crappiest You'll have to be more specific if you want to know if the paint is making your problem worse
Signature Quote Quote:
#6 | |
Property Manager
Re: How To Avoid "framing"?Quote:
steve |
#7 | |
My custom title
Also, there is a term called "Dutch roll", the practice of running the roller sideways as close as you can to the top and bottom cut lines... takes out alot of junk cut for semi/eggshell.
Benn Quote:
Property Manager
Please expound!! Maybe I have something to learn after all these years.
steve |
#9 | |
Property Manager
Thanks!! steve |
#10 | ||
...jammin
Though I've often used that technique, I didn't know there was a name for it I just had to use what I learned as a "French Roll" above a chair rail It had a slightly glossy sheen, and the cut-in above the chair rail was highly visible with the light from the window/wall and being so high It's one of the few things I'll use tape for
#11 | |
...jammin
Roll closer into the cut-in while the cut-in is still wet
#12 | ||
My custom title
Benn Quote:
Trade: Painter
Steve,
I've held many income property accounts over the years and my first job as a painter was for a property mgt. company. You definatley don't need classic 99 for an income property. Use the Pro Mar line. It's advertised as a contracors paint, but don't let that put you off. It's an excellent product. 200 is top of the line, 700 is the next step down and 400 is the cheapo stuff. If you're doing 2 coats, go with 700. It covers just fine, is very touch up friendly and is "self priming". If you done a lot of apartments, you'll learn what needs to be primed with kilz and what doesnt'. Whatever doesn't need to be kilz'd you can just paint over with pro mar. In the area of work you're doing, it's standard practice to paint all the units the same color, same paint, and in the pro mar line, you can even get the same batch for quite a while. whoever mentioned that you should lay down more paint with the brush is right. Lay it on there. Use a common off white, like dover and wait until the next day to see if it's still picture framing. Is this a smokers unit by chance? Also, I use the most expensive lamb roller they have. It's lasts forever, you can really lay down a coat of paint with it, and you can control the texture left behind simply by rolling it out a few more strokes. The texture of a lambs wool may look scary when wet, but dries nice. S/W produces their own paint. They even mfg. Pratt&Lambert for whoever bought them out. Last edited by Joewho; 09-26-2006 at 10:13 PM. |
Property Manager
So cutting in one wall (and rolling the same wall) at a time or using Floetrol in my latex would be the hot set-up??
Thanks for the great info steve |
#15 | |
...jammin
Same as a Henway
I'm glad you all could expound on all of my tips!
#17 | |
Property Manager
Just my opinion. Thanks for the reply steve |
#18 | |
My custom title
Benn Quote:
#19 |
Moderator
Before Venitian Red got so popular, Oriental Red was the shizzle. When working over the top of a built-in hall wall table, I've had to use what is known as an "egg roll". Did the trick.
#20 | |
...jammin
...not falling for it eh, Benn?
Lol I taped off the chair rail and brought that roller so close to the chair rail that they'd be considered married in 14 states
| Unconditional Disclaimer | Ed the Roofer | Business | 4 | 01-27-2007 04:44 PM |
| How to avoid paying for an architect? | robk | General Discussion | 13 | 01-13-2005 12:05 PM |
