How To Address Too Much Moisture
Old 07-08-2008, 08:43 PM   #1
Philly Dude's Avatar
When using a moisture meter, how do you address exterior house trim that has too high of a moisture content to paint ?
The house I am painting now has some trim at ground level that when probed with a moisture meter is WAY to moist to paint. The doors that this trim goes around I plan to unhinge and let dry out in the sun. For the remaining door trim I plan to talk to the owners and tell them it must be replaced because it is unpaintable.
Philly Dude is offline
Old 07-08-2008, 09:19 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: How To Address Too Much Moisture
If, after a week of sun (three days if it's full sun no shade at all), it's still too wet to paint, they have other issues
They'll need to take care of those issues, other-wise most coatings will just come off anyway
Signature Quote
slickshift is offline
Old 07-08-2008, 11:17 PM   #3
The trim I was referring to is on the north side of the house, so it never sees direct sunlight. It is also at ground level it a semi-enclosed area that is good for trapping moisture.
Old 07-09-2008, 06:33 AM   #4
...jammin
slickshift's Avatar
Just don't let your girlfriend use it on her hair
It will melt her head
Signature Quote
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
Tenwolde's 5 Myths Of Moisture Ed the Roofer Roofing 3 02-10-2008 03:37 PM
Moisture Problem Milhaus Commercial Construction 6 12-26-2007 02:47 PM
Screen Sanding & Moisture Cure Finish plazaman Flooring 3 01-28-2007 02:40 PM
Acceptable moisture content of unfinished hardwood Grainywood Flooring 2 09-24-2006 08:46 PM
