Old 07-01-2009, 11:36 AM   #1
NAV
Trade: commercial building restoration
Hot Dipped Galvanized Prep - blast or acid wash
I have to bid a job to brush blast and paint a galvanized light pole - 100 feet high (its on the ground now)
Anyone know if an acid wash is sufficient prep for hot dipped galvanized or do i have to brush blast?
materials are Macropoxy primer and Acrolon 218hs top coat.
I have painted galvanized before but never new hot dipped galvanized.
NAV is offline   Reply With Quote
Old 07-01-2009, 04:56 PM   #2
vandy
Trade: painting, decorating, wallcovering
Hey NAV,
It's been while, but I have used a product designed to prime galvanized metals without blasting at all.
It's called GalvaGrip, and it's made by Madison Chemical.
It boasts of not needing to blast.
Check it out.
vandyandsons is offline   Reply With Quote
Old 07-02-2009, 07:11 AM   #3
NAV
I can not change the spec.
I am going to go with Clean and Etch to prep the pole. I looked at the job yesterday and got the contract this morning. We are heading out in about an hour.
I hope the acid wash preps it good enough because it will kick my a** to have to touch it up after they put it up.
I will look into that product for future application needs, thanks
Old 07-03-2009, 05:56 AM   #4
Sarcastic Prick
Trade: Paint and Floor Covering Retailer
Blasting is best but a phosphoric acid wash should do the trick. We usually use a product called Ospho.
http://www.morrispaint.com
gideond is offline   Reply With Quote
Profitable turn key specialty blast company for sale Blastman Sandblasting 1 06-16-2009 07:48 PM
H and C acid stain Traditions2 Painting & Finish Work 1 02-05-2009 08:27 PM
acid staining questions Traditions2 Painting & Finish Work 3 09-22-2008 12:16 PM
Paslode RounDrive Hot Dipped Galvanized Plus! Nails anyone? cmansmith Framing 0 07-14-2008 12:13 AM
Cleaning a floor to prep for acid stain. joasis Flooring 1 06-12-2007 02:16 PM
