Trade: Carpentry/Handyman
High Gloss Finish On ACX Ply
I'm gonna be building a built-in bookcase, and I wanted to use 3/4 acx ply for the boxes. Does acx ply take paint well? Will be using water based primer and paint per plywood manufacturer.
Thanks in advance! |
Trade: commercial building restoration
Re: High Gloss Finish On ACX Ply
looks like you already did the research. I would listen to the plywood manufacturers specification when coating their material.
Thanks NAV. Yeah, I was just reading the display they have over at Lowe's, they say not to use oil base primer. But, I'm just wondering if I'm gonna end up with a nice smooth finish, providing my prep work is good.
solar guy
Trade: solar contracting
You are building cabinets and are desiting to put a gloss finish on them and use AC plywood? Are these going to be outside? If not spend the few extra bucks and buy birch or maple plywood and stop beating yourself up on the prep. No amount of sanding will make that very smooth and once a latex coating is applied the grain will swell and look bad anyway
| The Following User Says Thank You to naptown CR For This Useful Post: | RickS (06-24-2009) |
#5 | |
Re: High Gloss Finish On ACX PlyQuote:
#6 | |
with oil base primer, even shellac won't raise the grain like water base.
#7 | |
Btw, I appreciate the responses guys! This site kicks a**! |
#8 | |
Where are you? \/ \/ \/ \/ \/ \/ \/ \/ \/
Re: High Gloss Finish On ACX Ply |
Home Depot aisle walker
Trade: home remodeling
Maybe flat paint and water based poly on top of that, more durable.
#11 | |
I have never heard of any reason not to use oil primer on wood. I know lots of reasons not to use water base. Perhaps you are mis-reading something? Post a link (just leave out the http:// part).
solar guy
If this were an exterior application I would use a latex however these sound like book cases which would be inside. I would use an alkyd primer so the grain doesn't swell too much and sand again after. Just be aware that the gran and boat patches will show through and a gloss finish is not at all forgiving
I went back to Lowe's and sure enough on the GP display it says they don't recommend using an oil base primer or paint on their BC grade of plywood ( thought it was ac , but it was bc) and the guy in the paint department couldn't tell me why. I'm starting to think that maybe I should just get the hardwood ply, I only need 5 sheets, so we're only talkin' a $100 or so.
Thanks for the help guys! Last edited by RickS; 06-15-2009 at 10:11 PM. |
Well, here are the bookcase I did. I ended up using the birch ply for the boxes, and I'm glad I did, it took the paint nicely!
| The Following User Says Thank You to RickS For This Useful Post: | Metro M & L (06-24-2009) |
| Paint or stain on hardi plank? | Jer | Painting & Finish Work | 25 | 12-24-2009 01:10 PM |
| Hourly Rate for Finish Carpentry in Seattle | Donnie B | General Discussion | 33 | 09-05-2009 11:39 PM |
| pecky cyprus finish help | rbeck3@ec.rr.co | Painting & Finish Work | 6 | 02-02-2009 12:43 PM |
| Refinishing an exterior door - finish suggestions wanted | Haydin | Painting & Finish Work | 4 | 08-19-2008 10:41 AM |
| Stripping old deck finish | joedonuts | Painting & Finish Work | 26 | 06-09-2007 11:34 PM |
