High Build Primer For Drywall New
Old 08-07-2007, 10:32 PM   #1
plazaman's Avatar
Just a very Crazy thought here, but do you think its possible to spray or roll a high build primer without even sanding new drywall? I want to skip the sanding step and go straight to the primer.
Again, i have no intentions of doing this, but just a crazy thought.
plazaman is offline
Old 08-07-2007, 10:58 PM   #2
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Re: High Build Primer For Drywall New
ModernStyle is offline
Old 08-07-2007, 11:39 PM   #3
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Send a message via AIM to MarvinWilleyJr
Ever heard of Equilizer? I have seen the dry wallers use it as a final coat. It like a mix between primer and mud. They use it for slick finishes.
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand.
MarvinWilleyJr is offline
Old 08-07-2007, 11:54 PM   #4
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
Some of the guys out here mix mud with water to thin it out, then roll it on heavy and wet one wall at a time. Then a guy follows behind with an 18" blade and lays it down to a fast level five smooth finish. Still need a very slight sand but a great way to get an excellent finish fast...
We also spray a heavy coat of Hamiltons on new rock, backrolling to even it out which works pretty good at keeping sanding to a minimum.
Bay Area Painting Company
Da Vinci is offline
Old 08-08-2007, 12:25 AM   #5
villiage ideeut
LouisZerr's Avatar
Trade: painting contractor
[quote=Da Vinci;273475]Some of the guys out here mix mud with water to thin it out, then roll it on heavy and wet one wall at a time. Then a guy follows behind with an 18" blade and lays it down to a fast level five smooth finish. Still need a very slight sand but a great way to get an excellent finish fast...
quote]
Hamilton's? As in Hamilton's Prep Coat?
LouisZerr is offline
Old 08-09-2007, 07:52 AM   #6
premierpainter's Avatar
No way, High Build is not thick enough to cover un-sanded mud
premierpainter is offline
Old 08-09-2007, 11:32 PM   #7
Da Vinci's Avatar
Sorry- I misunderstood. I thought plazaman was talking about finished rock/mud- referring to the "fuzz" that occurs when priming new rock. We always sand first then patch/spot prime before painting. Guess that's what I thought he was referring to- not unsanded tape joints/mud- geez, no paint can cover that- even ter polymers.
Yes, I was referring to Hamiltons Prep Coat....
Da Vinci is offline
Old 08-10-2007, 04:34 AM   #8
Joewho's Avatar
Trade: Painter
It is crazy, but...in real world applications, it does happen. Depends on how well the tapers smooth the walls. Usually, HB paint is used. The high build is just an extra. The main trick to this is to get the flattest paint with a color that just blobs everything, to the point that your eyes can't focus on imperfectons.
People who automatically feel the walls with their handswill find it right away.
Sucks on a repaint because the customer usually doesn't see anything wrong. You have to show them where unsanded mud has been painted over, and then fix it.
Joewho is offline
Old 08-11-2007, 09:40 AM   #9
Estimator
DavidNTX's Avatar
Trade: Estimating
There is no way to get around sanding. Even 24 oz. commercial grade VWC won't hide unsanded drywall.
Exactly what color is it that "blobs everything together" to a point your eyes can't focus on it. Perhaps some multicolors might have that effect to a degree but no single color will.
DavidNTX is offline
Old 08-12-2007, 07:59 PM   #10
Joewho's Avatar
Trade: Painter
First, I"ve never painted over unsanded drywall. The flat off whites without too much red, but black tints will do the blob trick.
Joewho is offline
Drywall primer peeling problem?? DeanV Painting & Finish Work 23 02-02-2008 11:02 AM
High build, high gloss urethane rhinoguy Flooring 1 02-27-2007 06:28 PM
Anyoen build 8 ft high masonry steps? ruskent Masonry 7 02-13-2007 09:15 PM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 05:35 PM
