Here's A Good One From A Dumb HO...
Old 02-20-2008, 05:39 PM   #1
Dorman Painting's Avatar
Trade: Painting Contractor
A repeat client of mine called me to paint her bathroom, some knick nack trim here and there and a couple of walls. No big deal, I went to look at it Monday and told her I could get on it immediately. When I went down there Monday, I noticed her husband had caulked the trim in the bathroom, some crown molding, baseboard and the door casing. They put all new trim in the bath. I also noticed that the caulking felt wet and I asked her when he did it. She said several days ago, so I thought something was strange.
I go down there today to start and after sanding everything start applying the trim paint and it becomes an absolute nightmare. Her husband apparently used nonpaintable silicone type caulking that when painted, the paint just pulls apart. I cut out some of it but also caulked over what I couldn't get out. this job just went from being a one day job to a full two day job. She kept saying I'm so sorry, we didn't know what kind of caulking to use. I just hope I can make it look decent, I was having a awful time with this mess. HO's have NO clue about proper procedures and products...this job just went up another couple hundred dollars and she's not going to like it one bit either.
Dorman Painting is offline
Old 02-20-2008, 05:46 PM   #2
Thom
thom's Avatar
Re: Here's A Good One From A Dumb HO...
I've had counter top installers use that stuff. The best way is the lightly caulk with latex over the top, then paint.
thom is offline
Old 02-20-2008, 06:11 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Originally Posted by Dorman Painting View Post
...silicone...caulking...
< shivers and hair on back of neck stand up >
Signature Quote
slickshift is offline
Old 02-20-2008, 06:17 PM   #4
...jammin
slickshift's Avatar
Actually the best was is to remove it and do it properly
The second best way, if removal is not possible, is an alcohol rub and two light coats of BIN then top coat and pray
A light scuff and paint, or a light caulking over it might work
But not as often/well as the BIN
Signature Quote
Old 02-20-2008, 06:24 PM   #5
Fentoozler
Celtic's Avatar
Sounds like she hasn't agreed to the new charge either...as she hasn't been informed of it.
Celtic is offline
Old 02-20-2008, 07:00 PM   #6
No I haven't informed her of it yet, but I did make the comment to her that this is not what I bargained for. The main reason I didn't do a change order yet is because I really have no idea how much more time this is going to take. I don't want to tell her it's going to be another hundred bucks and then it turns out I should've told her three hundred.
I'm going to bill her for my extra time at the end of the job...that's fair IMO.
Old 02-20-2008, 07:26 PM   #7
Moderator
Double-A's Avatar
If this is not a large bathroom, would she be better off removing the trim and the silicone residue and just starting over?
New York Times, July 20, 2006
Double-A is offline
Old 02-20-2008, 08:43 PM   #8
BCPNJ's Avatar
Trade: All phases of quality custom residential painting work
Good ol sillycone. Do it right, charge it right, they'll appreciate it and call you first the next time. Tell her that next time if her husband uses a caulk gun, you'll just have to kill him.
BCPNJ is offline
Old 02-21-2008, 03:14 AM   #9
toddcla2002's Avatar
Trade: Paint Contractor
Send a message via AIM to toddcla2002
I've masked off the necessary areas and shot it with bonding primer before and it worked out ok. I don't know if it will in your situation. I noticed that Sherwin Williams now sales silicone caulk at my local store and it's mixed in with all the other caulks. It doesn't say whether or not it is or isn't paintable. I did a test and it isn't. I can't believe they don't have it labeled....sheesh. Anyways have fun wrapping it up with that client.
~todd
toddcla2002 is offline
Question on RTA Cabinets and a good counter top Project53 Carpentry 13 11-23-2010 01:53 PM
Estimate sounds good, but now wants more JamesNLA Business 25 05-24-2007 04:51 PM
Good idea/bad Idea Casework King General Discussion 5 04-04-2007 08:01 PM
Is that marketing tool a good idea or a cheap one? WaltG Marketing & Sales 5 03-20-2007 10:15 PM
Key Elements to Being a Good Businessperson elvinstheman Business 13 03-16-2007 03:44 PM
