Trade: paint
Help With Painting Rough Cedar Beams
Hello all....I've been lurking for some time and have enjoyed and learned from you all!
I have a job in which the ceiling has recently been skim coated between rough cedar beams (they are stained dark). Each beam has been trimmed with a 1.5" wood trim on all sides (between beams and sheetrock...and between beams and 1/2" tongue and groove paneling on walls). I plan to caulk the mouldings which surround the beams. How do I prep these beams? Oil or latex primer? Small roller or brush? Do most people enamel these types of beams or will latex suffice? Any and all help with this problem would be GREATLY appreciated as I must start this ceiling area when I am done with the adjacent stairwell and ceilings. Jason Kansas City |
Re: Help With Painting Rough Cedar Beams
Is this your house, or is it being done for a customer? If for a customer, what finish do they want? More info would be helpful!
Trade: Hanger taper finisher painter
Your primer/sealer should be oil based. Ceder can bleed through waterbased primers. As far as a top coat latex is fine. Depends on what finished look your customer wants. Flat, satin, semi gloss , high gloss. The more shine you have the more the roughness or imperfections are seen. Something to consider.
#4 | |
...jammin
Trade: Rock Disciple
Re: Help With Painting Rough Cedar BeamsQuote:
Latex will not cut it Myself, if I don't want it to bleed through for sure, I'd shellac 'em Dark cedar, I probably would whip out the BIN Latex over that would be fine, but really depends on what the customer is looking for How to apply? Depends on how rough rough is Splintery rough I'd get the rattle can BIN and brush the color Lumpy rough I'd probably try and roller it You may have to try it and if it doesn't work well, try the other |
#5 | |
Pro Painter
I'd recommend giving the whole thing a light sanding as well before applying your primer to break up the surface a little and give your primer some tooth over the old stain. For me, it would be BIN primer on something like cedar. I wouldn't want to see tannin stains coming through in the future.
Cedar is so soft that just a little time sanding will make it smooth, if that's what the client wants. B-I-N is definitely the way to go. Apply 2 coats just to make sure that you don't miss any spots and then paint with whatever you want.
#7 | |
Pro Painter
You're absolutely right Teetor. That's why I only recommend a light sanding. Knock a little of the high stuff off, no digging in. Just a couple light passes is all something like that needs because I'm willing to bet it's grip on that stain isn't what it used to be.
Trade: General
ditto with the BIN. you need something shellac based for any kind of wood with knots. i'd finish it off with an oil based paint too.
Bah Humbug!
I'm not a painter but I do a fair ammount of cedar work and have been told cedar requires special primers due to the tannins (natural resins) in the cedar. I have also been told that paint should not be used but instead solid color stains should be used. Cedar has so much natural tannins that it is likley the paint will peel as these natural resins and oils escape the wood.
Like I said I am no painter. |
#10 | |
| FS 6"x10"x14' rough saw'n pine beams | gsp | Contractor Swap | 2 | 06-05-2007 01:10 PM |
| Rotten Beams - must replace | MHMConstruction | Remodeling | 8 | 03-05-2007 04:45 PM |
| very rough cedar siding | painterofeveryt | Painting & Finish Work | 10 | 07-26-2006 05:23 PM |
| Rough Stucco Painting | baspinall | Painting & Finish Work | 4 | 05-16-2006 11:03 AM |
| Staining Rough Cedar | lpp | Painting & Finish Work | 12 | 05-05-2006 10:45 PM |
