HELP! How To Get Two Paint Drops Out Of A Canvas Windowshade
Old 11-18-2006, 08:27 PM   #1
Gregevansny@aol's Avatar
Unhappy
OK, i got two drops of paint on a very nice canvas pull-down blind. The paint is P&L Accolade Velvet, medium toned green. It was dry by the time I saw it. They won't scrape off. Any suggestions as to getting them out? If it calls for professional cleaning, what kind of cleaning is needed? Thanks!:
Greg
Gregevansny@aol is offline
Old 11-18-2006, 10:02 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: HELP! How To Get Two Paint Drops Out Of A Canvas Windowshade
Did you try water and a soft cloth?
Maybe (gulp!) some Goof-Off. Try in a small inconspicuous spot first.
The longer its there, the harder it will be to get off.
ProWallGuy is offline
Old 11-18-2006, 10:15 PM   #3
Teetorbilt's Avatar
Most paints take 48 hrs, to 'cure'. Keep it wet and it should come off with a little brush (toothbrush) work and dish detergent.
Note to self, all canvas below painting should be kept wet! A cheap sprinkler can accomplish this.
Albert Einstein
Teetorbilt is offline
Old 11-18-2006, 10:46 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
If it won't scrape off, try Oops! or Goof Off
Yeah I'd test it first, it may affect the color of the blind
Signature Quote
slickshift is offline
Old 11-18-2006, 11:07 PM   #5
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Wait....before you try goof off, try a little bit of EZ Brush Cleaner. This works very good to clean up latex and even small oil spills. It doesn't usually cause a problem like washing out colors and stuff. You can even dilute it a little with water and try it that way first just to be sure. It's a very mild solvent that works very good. We use it on hinges and things like that if they get bumped or something.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 11-19-2006, 07:38 PM   #6
Mike Danahy
Danahy's Avatar
Trade: Signature Painter
Hand Cleaner works!
Yes, especially nice is that new dynamic orange smelling stuff with pumus in it, rub that on, then rinse / dab with wet water. (comes in sqeeze bottle, like hand cream or shampoo type thing)
I actually have been able to romove oil paint from clothing with this stuff. (Time is definately of the essence as with any spills).
I don't find this as harsh as other cleaners with the chemicals and such.
Danahy is offline
Old 11-19-2006, 08:32 PM   #7
ProWallGuy's Avatar
Anybody think he'll post back with what he did, and if it worked?
Old 11-19-2006, 08:51 PM   #8
Mike Danahy
Danahy's Avatar
I'm betting = Nope
Danahy is offline
Old 11-19-2006, 09:49 PM   #9
Well, here I am, posting back, sort of. Unfortunately this happened on Friday, which means 48 hours have come and gone. The job resumes tomorrow (Monday) and the client is already aware of it. I didn't want to go the Goof Off/Oops! route because sometimes that makes a bad situation even worse (like if it leaves a water mark or similar discoloration or the fabric gets scuffed up from excessive scrubbing). What about (literally) boiling water dipped onto a Q-tip and a little hand cleaner? Or steam cleaning?
Thanks for all the replies, will check back again.
Greg
Old 11-19-2006, 10:24 PM   #10
My custom title
Brushslingers's Avatar
Canvas... use some orange hand cleaner from the local car parts store and hot water.... you'll be fine.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 11-19-2006, 10:51 PM   #11
metomeya's Avatar
I vote for steaming.
metomeya is offline
Old 11-20-2006, 02:20 AM   #12
Woz the Painter's Avatar
I'd put it through a dense radioactive bombardment and see what happens...
Woz the Painter is offline
Old 11-20-2006, 08:42 AM   #13
copusbuilder's Avatar
Trade: Builder/Remodeler- Master Electrician
Don't be ridiculous! This guy is in trouble and needs answers...I suggest he cuts them out
copusbuilder is offline
Old 11-20-2006, 01:26 PM   #14
Or maybe paint the entire blind...
Old 11-20-2006, 02:05 PM   #15
Pro Painter
AAPaint's Avatar
Lean your ladder on it, then fall through and tell the HO they are lucky you aren't suing them for the hazard!
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 11-20-2006, 06:14 PM   #16
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
That is way funny
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 11-20-2006, 06:20 PM   #17
Mike Danahy
Danahy's Avatar
colour match a tester pot to the same colour as the blinds, then paint the dots?
Danahy is offline
Old 11-20-2006, 09:53 PM   #18
BMAN's Avatar
Trade: Painting & Remodeling
kRUD kUTTER?
BMAN is offline
Old 11-21-2006, 01:39 PM   #19
pdity's Avatar
Trade: painter
lift off for latex or krud kutter both found at home depot
pdity is offline
Old 11-21-2006, 03:29 PM   #20
Joewho's Avatar
Trade: Painter
Using a stiff bristle brush, flick paint on all the windowshades and charge for the extra.
Joewho is offline
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 07:59 AM
Short Review Of Aura Paint Riverside Paint Painting & Finish Work 30 03-07-2009 08:50 PM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 08:43 PM
