Old 04-12-2006, 05:20 PM   #1
Trade: Roofer/Sider
help with 2 story foyer
i am a roofer na dsider by trade. i just had a house built. i do not like to paint but do it in my own home just because......anyways i have a 2 stroy foyer,, any advice on cutting in along the ceiling up top??? i have no scaffolding or anything lik that, i have linoleum floors and am wondering if i set a ladder will the feet dig up the floors, also, if i am up on ladder what can do about holding a paint can up there ?? i thought about setting a ladder in the foyer with a ladder \jack on it and setting a pick on the top stair to the ladder ?? any advice would be helpful
Starboyz66ftp is offline   Reply With Quote
Old 04-12-2006, 06:03 PM   #2
You can use an extension ladder, just make sure you have boots or rubber feet on the bottom, and if you think their is any possibility of your ladder slipping out on your lino, have someone foot the ladder while you are cutting in. I would also recommend putting ladder mitts or wrapping foam rubber and taping to top of ladder to prevent sliding and or damage to drywall. Get yourself a pot hook to hold your cut pot to your ladder while cutting in. Just be carefull to make absolutly sure that the ladder wont slide on your floor. Best of luck.
Woz the Painter is offline   Reply With Quote
Old 04-12-2006, 09:56 PM   #3
Trade: interior paint contractor and window treatment workroom
once i was up cutting a 17 ft ceiling line and the ladder slipped about 6"...yiks...had to force myself to go back up there....i have been using a bathroom mat with the non-slip backing on it under my ladder feet and it seems to hold the ladder in place well. good luck
lornmastro is offline   Reply With Quote
adding 2nd story to block house 72chevy4x4 Construction 3 01-21-2007 09:20 PM
2 story porch on a modular condo!! Help craker Framing 3 11-12-2006 08:12 AM
40 story high rise apartment - Estimation Help shame Painting & Finish Work 10 12-02-2005 06:57 PM
Crown molding in a 2 story foyer? CJAllen Finish Carpentry 4 02-11-2005 01:45 PM
