Hardie Plank?
How do you guys paint your Hardie Board? Its actually in the form of Cedar Shakes but its Hardie Board? Just curious.
#2 | |
Pro Painter
Re: Hardie Plank?
I just spray it...if that's what you're asking.
Re: Hardie Plank?
Yeah, thats what I was asking but it just seems like spraying makes such a mess and its alot of prep to spray an exterior. Ever tried rolling it? Wonder how it would go.
#4 | |
Pro Painter
Re: Hardie Plank?
Rolling would go extremely slow for what you're talking about and you will work yourself to death. Spraying exteriors is very easy once you get the hang of it. Learn to use a shield, the right size tip, and avoid windy days you'll have no prob.
Get yourself a bunch of huge cardboard boxes and use pieces of those for shields...or better yet if you can find those big 4x8 sheets of corrugation like they use in shipping to cover pallets. You can cut one to fit absolutely any shape you need in just a few seconds right on the spot. You can wrap a box around an area you are spraying and box in the overspray, or you can do it the other way and box in say a flood light while you spray around it. The cardboard can cover far more than a standard spray shield, so your worries of blowback in corners is also reduced by just using a bigger peice of cardboard. Say you're spraying soffits, and there's a dang wire that won't let you put your shield flush to the fascia...just cut a little notch and move on... It's all about efficiency. The faster we complete something, the sooner we can move on to the next project...means we can make more money. Our prep to spray an exterior means setting up the pump and getting the cardboard and ladders ready to go. Hey, it's my 1,000th post!!
Bah Humbug!
Re: Hardie Plank?
I buy mine pre-stained with a 15 year color warranty so they don't need to be painted. Sorry painters, it also osaves the customer alot of money. From what I have read, paint should not be used. Solid color stains should be used instead. That's what the pre-finish factories use for "painting".
#6 | ||
Pro Painter
Re: Hardie Plank?
Paint is just fine on hardi board if it's applied properly. I've yet to see a problem from painting it because paint adheres extremely well to that stuff. Solid stains don't offer half the color choices that paint does, and it will eventually end up getting painted if they want more than just 8 color choices.
General Contractor
Re: Hardie Plank?
http://www.superdeck.com/palett5800.htm
Gives a 25 year guarantee on painted finish. http://www.superdeck.com/masonsselect/6700spec.htm Warranty of 12 years on the stained with a limited # of hues. I had them do a mahogany stain on some (haven't installed yet) and they are doing a painted job for me right now - Cocoa for trim and Autumn Sand for siding. The stained runs about $1.72 / sf for material and finish. Painted is about $1.38 / sf (that's installed square footage). |
ROG OF DCA CUSTOM PAINTIN
Re: Hardie Plank?
When It Comes To Hardie Plank I Just Spray Usually Durations On It With A 5-19 And Back Brush It..well Have A Lackey Back Brush It With A 4 Inch Block Brush It Sinks It Deep Into The Cedar Look Texture And Holds Up Gr8...any Time
Rog |
Re: Hardie Plank?
On small stuff, 2 coats primer and 2 topcoats. I don't like the supplied primer, it sucks up the new stuff like a sponge.
Re: Hardie Plank?
What type of primer have you guys been using to prime your Hardie Shakes? Whats good or whats bad?
#11 | |
Mod / ArchiBuilder
Re: Hardie Plank?Quote:
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
#12 | |
Bah Humbug!
#13 | |
Bah Humbug!
Re: Hardie Plank?
I contacted James Hardie Corp. and they said that none of there Hardie Shakes come preprimed.
#15 | |
Bah Humbug!
Back to the original question, if I were to have to stain ths stuff I'd prefer to pre stain it myself before installation or if it had to be pained after, shake siding like this would be a B to do anything but spray. |
| Hardie Plank (per square rate of installation) | jimetime | Windows, Siding and Doors | 44 | 05-14-2011 03:18 PM |
| Hardie plank siding per square | Snl | Windows, Siding and Doors | 16 | 02-10-2010 10:49 AM |
| Hardie Shingle | Marker | Windows, Siding and Doors | 9 | 09-13-2008 10:32 PM |
| Installing Hardi Plank Siding around windows w/ J channel | brownie77 | Windows, Siding and Doors | 8 | 11-21-2007 08:52 AM |
| hardie plank install price? | willbone3 | Construction | 10 | 05-11-2006 12:52 AM |
