H&C Shield Crete Epoxy
Old 03-04-2009, 06:52 PM   #1
420sully's Avatar
Trade: Garage Floor Coatings
Just curious if anyone has used H&C Shield Crete Epoxy for garage floors?
420sully is offline
Old 03-04-2009, 08:59 PM   #2
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Re: H&C Shield Crete Epoxy
I have done it, but I dont give a warranty on it. I have had a few people who do floors for a living tell me it isnt that great.
ModernStyle is offline
Old 03-06-2009, 07:51 AM   #3
A bit abrasive.
WisePainter's Avatar
I used it and found that I was better of with another product.
WisePainter is offline
Old 03-07-2009, 12:16 PM   #4
420sully's Avatar
what would you recommend?
420sully is offline
Old 03-07-2009, 12:34 PM   #5
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
It's virtually identical to the Rustoleum product you see in most stores. There is a solvent based and waterbased version of it though. Solvent based is definitely the better of the two but neither is all that great. If you want epoxy go for an industrial two part floor coating. There are a lot of good high solids urethanes out there as well.
http://www.morrispaint.com
gideond is offline
Old 03-07-2009, 09:19 PM   #6
420sully's Avatar
Has anyone used Tile Clad HS from Sherwin Williams to do garage floors? Or any other companies products? I'm trying to get started doing garage floors but not sure what product to start using. Any help would be great.
420sully is offline
Old 03-08-2009, 09:36 AM   #7
A bit abrasive.
Armor Seal 1000 epoxy from SW is what I use.
Old 03-08-2009, 07:21 PM   #8
420sully's Avatar
With a clear coat from armorseal as well? Good for doing garage floors?
420sully is offline
Old 03-09-2009, 09:05 AM   #9
A bit abrasive.
The Armor Seal doesn't need a clear coat. It has a high build sheen and you can buff wax the floor and strip that when you need to perk up the appearance.
Old 03-09-2009, 09:10 AM   #10
A bit abrasive.
The Armor Seal doesn't need a clear coat. it has a high build sheen and you can buff wax the floor and strip that when you need to perk up the appearance.
Old 03-09-2009, 09:10 AM   #11
A bit abrasive.
Hey look, I double posted!
Old 03-09-2009, 08:19 PM   #12
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
I've used epoxy-coat on two garages so far. Prep work is key.
Eric K is online now
Old 03-09-2009, 10:30 PM   #13
420sully's Avatar
What about decorative flakes? Can you use the ones from Home Depot with Armorseal, and do you not recommend? Do you always put a clear coat on with the flakes?
420sully is offline
Old 03-09-2009, 10:31 PM   #14
420sully's Avatar
who makes this product?
420sully is offline
Old 03-09-2009, 10:37 PM   #15
A bit abrasive.
Flakes do require a clear coat.
As far as chip colors go, you can find whatever you could possibly ever need HERE <---click on that
Download the PDF file to view all the available colors.
Old 03-10-2009, 05:51 PM   #16
420sully's Avatar
Thanks for the help Wisepainter. I checked out that website, have you used that product before??
420sully is offline
Old 03-10-2009, 07:06 PM   #17
A bit abrasive.
Not that company specifically, but paint chips are paint ships no matter where you get them.
Old 03-10-2009, 10:54 PM   #18
Interior Remodeling
Eric K's Avatar
epoxy-coat is the company or brand. google them for the site, dont want to advertise there site.
Old 03-11-2009, 12:50 AM   #19
Boss-man
WoodShop's Avatar
Trade: Woodwork & Coatings
H&C is ok... their statement that acid etching is not required is a lie. I wouldnt lay one without doing it first.
WoodShop is offline
Old 05-11-2011, 08:54 AM   #20
Rave's Avatar
Trade: Garage floors
Armor Seal Stinks I have used it for garage floor applications both without clear and with clear. in both instances the paint turns a brown yellow every spot the tires are parked. AND IT WONT COME OUT.
It takes over 2 months to full cure until this stops happening.. then a short time after that it yellows.
Rave is offline
Help, old shingles stuck to ice shield??? 232323 Roofing 45 09-16-2009 04:27 PM
Epoxy Coat on top of Epoxy Coat DiversifiedHR Painting & Finish Work 13 02-16-2009 09:22 PM
shield material Cache Painting & Finish Work 28 02-10-2009 11:00 AM
Bathroom epoxy paint PARENOS Remodeling 5 01-22-2009 08:23 PM
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 11:00 AM
