Old 12-03-2006, 12:50 PM   #1
Goggles for Paint Spraying, that are COMFORTABLE!
I got those cheap goggles from home depot, they don't fit well over my noise, and my respirator (3M) hits the lower piece!
What type of goggles do you guys use?
I was looking at these:
link
metomeya is offline   Reply With Quote
Old 12-03-2006, 03:06 PM   #2
Professional Painter
Richard's Avatar
Trade: Owner/Operator
just try out a clear pair of safety glasses with side protection...they work fine for me
Rich
Richard is offline   Reply With Quote
Old 12-03-2006, 04:31 PM   #3
Got a link Paintguy26?
I've seen wrap around, but not side protection glasses.
Old 12-03-2006, 04:50 PM   #4
LennyV-NHSNOLA's Avatar
Trade: Residential Renovations/Remodeling
Don't buy the cheapest safety glasses though. For me, the cheapo ones always fog up. I usually spend under $10.00 for a decent pair of safety glasses. I wear a ball cap so the bill covers the top. When I'm spraying, I wear a good filter mask over my nose/mouth.. not one of the doctor type things held on by elastic but one with replaceable filter pads for various chemicals. Clean the glasses with soapy water after each use or they will get spotted up.
LennyV-NHSNOLA is offline   Reply With Quote
Old 12-03-2006, 06:07 PM   #5
Richard's Avatar
Rich
Old 12-07-2006, 12:44 AM   #6
b34nz's Avatar
Trade: Finisher
Send a message via AIM to b34nz Send a message via Yahoo to b34nz
I use the 3M respirator/Face Mask combo. It was like $99 from Sherwin Williams I think. Very comfortable...
b34nz is offline   Reply With Quote
Old 03-13-2007, 12:15 AM   #7
Trade: painter
Are they comfortable to wear if you wear glasses?
STUMPFOOT is offline   Reply With Quote
Old 03-13-2007, 04:25 PM   #8
premierpainter's Avatar
Trade: Painting Contractor
Us too- can you believe that you can pay over $100 for a mask and it does not com with respirator cans. We have the easy fit ones that you "screw" onto your face until it is sealed. We then got the plastic film that sticks to it so it can be pulled off and replaced w/o having to clean it. Great mask though. I am sure you can wear glasses under it too
premierpainter is offline   Reply With Quote
Old 03-14-2007, 07:16 PM   #9
got the same one. thought its great before i used it--it makes me feel too isolated from everything else that goes on around (ladders, ppl moving, staircases, etc.); feels too claustrophobic and is too sweaty; can't see clearly either...
bgpainter is offline   Reply With Quote
Old 03-15-2007, 11:36 PM   #10
Trade: exterior painting contractor
check out motorcycle goggles. i use them for sanding, they dont fog, decent peripheral, and there the most comfortable goggles ive ever worn. i dont spray, but when i roll out a ceiling i just clean em with thinner when im done. maybe a little rainx or windsield oil will prevent the paint from adhering for easier clean up?
i got a tip for you makita guys out there, wipe your goggles with a dryer sheet before you start, it reduces the static of the plastic that attracts the dust, it almost repels it! it'll make your day!
farrellpainting is offline   Reply With Quote
Old 03-18-2007, 02:23 PM   #11
Trade: painting/remodeling
I i use advance spray goggles, available from swp. very comfortable , reasonably priced, semi-fog resistant
PAINTING GURU is offline   Reply With Quote
Spraying pressure, tips and mostly technique bgpainter Painting & Finish Work 11 08-12-2008 10:39 PM
all day spraying bgpainter Painting & Finish Work 21 04-13-2007 11:32 PM
spraying has ruined my brush and roll estimating Traditions Painting & Finish Work 11 09-15-2006 03:31 PM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 07:49 AM
spraying on stilts!!!!! drywall Drywall 5 07-06-2006 10:51 PM
