Glidden EZ Track Ceiling Paint
Old 02-21-2005, 03:46 PM   #1
autumnpaint
Guest
autumnpaint's Avatar
Posts: n/a
I'm contemplating trying Glidden's EZ Track Ceiling Paint that goes on pink and dries white. Has anyone tried it? If so, what do you think about it? Did it help speed up your job? If it did, how much time did it save you compared to using regular ceiling paint?
Also, it's about $3.00 more expensive per gal. than the regular Glidden Ceiling Paint. If you have used it, would you think the extra cost would balance out because the job took less time to complete?
Thank you
Old 02-21-2005, 08:38 PM   #2
George Z's Avatar
Trade: Painting Contractor
Re: Glidden EZ Track Ceiling Paint
It used to be you looked for the missed, white on white spots.
This paint goes on strong pink and then light pink. Now you
are wondering: "is this area drying or I didn't put enough paint?"
Total confusion at the end.The quality of that flat is not very good.
Unless your ceiling is well primed, it will be very chaulky.
Our ceiling paint is B. Moore's wall satin. More expensive than
ceiling paint but very smooth and worth it.
George Z is offline
Old 02-21-2005, 09:21 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
I think its just a gimmick for DIY'ers. Any good painter doesn't need pink to know where they rolled or not.
ProWallGuy is offline
Old 02-22-2005, 12:28 AM   #4
PlainPainter's Avatar
Those types of ceiling paints also do not dry as white as regular ceiling paints.
Go for a professional Contractor grade paint by any manufacturer like Benny Moore's SuperSpec or something like that. And just put on two coats, you'll be sure to hit everything at least once.
-PlainPainter
PlainPainter is offline
Old 02-22-2005, 10:14 AM   #5
autumnpaint
Guest
Posts: n/a
Thank you for your input and insight about this paint. I appreciate the information.
Ceiling Paint? steve-in-kville Painting & Finish Work 38 04-09-2009 08:04 PM
how to paint a textured ceiling 72chevy4x4 Painting & Finish Work 5 03-13-2007 11:23 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
