Glazing/clear Finish
Old 12-07-2006, 01:43 PM   #1
boman47k's Avatar
Would someone tell me the difference in glazing and just a clear protective finish such as poly?
boman47k is offline
Old 12-07-2006, 02:08 PM   #2
boman47k's Avatar
Re: Glazing/clear Finish
Okay, after a little quick search, I see color is involved in glazing. As you can see, I have no experience with glazing with color. I thought I had seen some clear finishes that were referred to as glazing.
boman47k is offline
Old 12-07-2006, 02:35 PM   #3
b34nz's Avatar
Trade: Finisher
Send a message via AIM to b34nz Send a message via Yahoo to b34nz
Sometimes a clear coat will get a "glaze" to it. But that's not a good thing. It's like another word for cloudy or haze. So a glazed topcoat is bad.
Another glazing involves color. Like stain or a thick stain called "glaze". Usually "glaze" is put in cracks and stuff to give the look of depth. But people use the word for all kinds of stuff. My boss calls the process of staining wood "glazing". So I dunno lol.
There is also "glazing" and "glaze" with faux wall finishes and stuff. There is millions of uses for the word. =\
http://jwpincorporated.com
Need a website for your company, free of charge? PM me for details!
b34nz is offline
Old 12-07-2006, 03:02 PM   #4
boman47k's Avatar
No wonder I am confused! LOL!
boman47k is offline
Old 12-07-2006, 03:04 PM   #5
boman47k's Avatar
And I have always thought of a hazing effect with the term.
boman47k is offline
Old 12-07-2006, 04:51 PM   #6
LennyV-NHSNOLA's Avatar
Trade: Residential Renovations/Remodeling
Don't forget glazed donuts. Mmmmmmmm.
LennyV-NHSNOLA is offline
Old 12-07-2006, 07:24 PM   #7
New York City
eastend's Avatar
Trade: historic woodwork restorations
glazing usually refers to wiping a pigmented liquid of varying viscosity on a sealed surface. It will often then be wiped off to different degrees to acheive the desired effect.
Clear coating is using a finish that is amber or waterwhite but has no dye or pigment in it.
eastend is offline
Old 12-07-2006, 07:30 PM   #8
boman47k's Avatar
I have used varnishes, sanding sealer, etc, but never did any glazing. Had my curiosity up.
boman47k is offline
Old 12-07-2006, 07:33 PM   #9
Mike Danahy
Danahy's Avatar
Trade: Signature Painter
Glaze added to paint, makes paint transparent. Glazing? Thought that was a window thing...
Danahy is offline
Old 12-07-2006, 07:53 PM   #10
b34nz's Avatar
Trade: Finisher
lol, like I said, there's like a zillion uses for the word...
b34nz is offline
Old 12-07-2006, 10:20 PM   #11
PaintPro's Avatar
Trade: Painting Contractor
Glazing has a longer "wet" time to work with it and is flat, has no sheen.
PaintPro is offline
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 04:41 PM
Stripping old deck finish joedonuts Painting & Finish Work 26 06-09-2007 11:34 PM
glazing over stained finish ChuckEA Painting & Finish Work 5 06-23-2006 09:21 PM
Can You Help Identify This Finish? Richie-C Painting & Finish Work 10 06-07-2006 09:34 PM
metal railing finish failed problem? a68cudas Painting & Finish Work 9 06-06-2006 03:37 AM
