Give Me A Good System For Painting Cement Board....
Old 02-26-2012, 06:32 PM   #1
Dorman Painting's Avatar
Trade: Painting Contractor
Rewards Points: 256
Tomorrow I'm going to be priming and painting cement board. I generally don't ask these types of questions but I never really get asked to paint cement board. It's on a garage and the customer is fairly picky. I was thinking about using SW's Super Paint for the finish and some sort of bonding primer for the primer. I'm not using Duration because I simply don't want to spend an arm and a leg for the paint.
Dorman Painting is offline
Old 02-26-2012, 08:43 PM   #2
Pelican's Avatar
Trade: Painting/Wood finishing
Rewards Points: 81
Re: Give Me A Good System For Painting Cement Board....
I would suggest using an oil primer intended for masonry surfaces. Just ask the SW rep what the best primer is for cement.
Pelican is offline
Old 02-26-2012, 09:23 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
usually it's preprimed,acrylic is whats recomended
Tom Struble is offline
Old 02-26-2012, 09:27 PM   #4
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Where the joints finished? Why cement board in the garage? Whats wrong with tinting block fill? So many questions. Also let him pay for the paint, so who cares how much it costs...
ohiohomedoctor is offline
Old 02-26-2012, 09:30 PM   #5
Trade: siding
Rewards Points: 20
oh i may have misunderstood, i thought you were talking fc siding
Old 02-26-2012, 10:23 PM   #6
Rewards Points: 256
I'm talking Hardie Board, on the exterior of the garage. I'm thinking just a regular bonding primer and then Super Paint Satin or Flat. Hardie board is obviously not porous and it's basically swell/rot proof because of it's design. Definitely going to be acrylic, noway would I use any oil primer or finish.
Old 02-26-2012, 10:42 PM   #7
Mad Italian
TheItalian204's Avatar
Trade: Licensed Mason/Owner of small business
Rewards Points: 2,004
THAT is really weird.
www.gabesmasonry.ca
Originally Posted by Mud Master View Post
I hate when a profitable job becomes a charitable write off.
TheItalian204 is offline
Old 02-27-2012, 06:39 AM   #8
Rewards Points: 256
The guy went absolutely overkill on this project and is a picky person too. The overhangs/trim is old school, I set nails and puddied them along with caulking all ofthe wood. So it's odd in the sense that it's not your typical vinyl garage.
I said Hardie board but not quite, it doesn't have the faux grain, it's just smooth cement board.
Old 02-27-2012, 07:37 AM   #9
Trade: siding
Rewards Points: 20
they have both smooth and grain,you can go on to the website
http://www.jameshardie.com/homeowner...painting.shtml
Old 02-27-2012, 04:43 PM   #10
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
If it was cement i would use the cement sealer/ prime that home depot has and then paint but it;s only cement board, so any high end acrylic primer should work , for the longest time all they ever suggested was flat paint for block cement but a more water resistant int/ ext primer is needed for an in/ext garage/. Too bad suffering an extra fussy, you would think that a prefinished board be so much more practical.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 02-28-2012, 09:43 PM   #11
shesbros's Avatar
Trade: Painting and Remodeling Contractor
Rewards Points: 213
Just use two coats of 100% Acrylic Quality House paint. We spec either California Freshcoat Flat, or BM Moorelife. California did a test a few years ago on the fibercement and thy got the best results with 2 coats of the freshcoat no primer. When it comes to the caulking I would recommend either the Dynaflex or the DAP 3.0. We have had excellent results.
shesbros is offline
Old 02-29-2012, 12:23 AM   #12
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,338
Hope you didn't caulk the laps just the butt ends....
Metro M & L is offline
Old 02-29-2012, 11:49 AM   #13
shesbros's Avatar
Rewards Points: 213
You mean under the claps? Ive only seen that done on the 200 yr old colonials. We just do the Butts.
shesbros is offline
Old 02-29-2012, 12:14 PM   #14
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,984
A top quality acrylic primer and Super Paint. You'll have a great finish.
Too bad about the Duration.......its sky high now. As are all SW products these days. They've bought up all the competition.
I'm just finishing my house with it. Deep base 68.99 net. They would only give me 10% off. Super paint is a greater discount. I used a 25% off coupon from the net. When I got set up with them about 5 yrs ago the salesman put in 28% discount - 10 - 40% off sundries. I don't do a lot with them and looks like they have combed through their accts and in my case now a preferred customer 10% off. The counter man said 10 off Duration - that's it. The others we agreed ~ 25 off I just need to be sure to ask.
Sorry about the thread drift. I guess I'm still obsessed with the SW price increases. What am I supposed to tell the customer.....their price is $72 for Super Paint, $90 for Duration ? I rarely tell the customer but I use these products because I don't want problems.
We Fix Houses is offline
Old 02-29-2012, 12:18 PM   #15
Trade: siding
Rewards Points: 20
most fc already comes primed at the factory,unless it's been exposed for more than 180 days repriming shouldn't be nessesary
Transitioning drywall with cement board Lone Wrencher Drywall 22 10-29-2013 08:59 PM
achieving a paintable fireplace surround with cement board ajmackenzie Painting & Finish Work 17 01-23-2012 02:30 PM
prefinished fiber cement board james hardi zconstruction General Discussion 10 04-13-2011 11:55 AM
Cement Board ? Abaco83 Tiling 16 11-30-2010 08:14 AM
Best way to cut 1/2 inch cement board? Spencer Tiling 92 08-27-2010 02:58 PM
