Getting Super Straight Lines.
Okay I do the tape with the caulking trick to get a cleans lines.
But the problem I'm facing is getting the tape really straight. Let me explain..... I have a wall that instead of being at a 90 degree angel, is at about a 45 degree angel. about 8 feet high. So I'm taping, and eyeballing it, relifting the tape, and placing it to where it looks straight. I even got those laser beams that show you if it is straight, and it looked pretty good. Well After I painting and lifted, the line is really clean, but where I relifted the tape there is like a bit of a curve to the paint line. Any suggestions on getting a straight line? I can't really put the tape down and pull it tight along 8 feet of wall can I?
#2 | |
...jammin
Trade: Rock Disciple
Re: Getting Super Straight Lines.
I'd recommend dispensing with the tape
The walls are rarely actually laser straight and square to the ceilings and each other I feel part of the painter's job is to split the difference and make it look like it is Often that means not painting laser straight
Signature Quote Quote:
Trade: Paint and wallpaper
I agree with slickshift. If you insist on using tape in an angle like that, you might just have to keep trying until you're happy with the line.
#4 | |
Pro Painter
Yup, I'd leave that one to hand/eye coordination only. As for your problem with the taping, be careful pulling on the tape and it's edges. You are most likely stretching the tape too much which will deform its edge and your lines.
Try Easy Mask
#6 | |
Painting Contractor
Re: Getting Super Straight Lines.Quote:
I hate to say this but... what's the tape/caulk trick?
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus' The NAPP Milwaukee Painting Contractor |
It's one of Houdinni's greatest tricks!
#8 | |
Painting Contractor
dangit... he's dead...
Trade: interior paint contractor and window treatment workroom
where is houdini when you need him!! i'm asking the same question...what is a chalk/tape trick??
If you hold a seance, you can rechannel him!
#11 | |
Painting Contractor
I haven't channeled him the first time...
Re: Getting Super Straight Lines. Houdinni would know this and not be bothered by it!
#13 | |
Painting Contractor
But seriously what the heck is this tape caulk trick?
#14 | |
Trade: Painting Contractor
You tape, caulk and wipe the critical side of the tape, so paint doesn't bleed through as it is sealed. I never tried it, I don't know if it works. You could also seal the tape with clear mat acrylic varnish, or some of the colour you are protecting, if you have it.
Toronto Painters Commercial Painting Commercial Painting Toronto Toronto Office Painters Painting Toronto Blog |
also heard you could do that with a faux glaze....anyone ever tried this before??
The Man
I use the dry brush method, works great
We Got Ya Covered
Trade: Painting/Remodeling Contractor
I've used the tape/caulk trick many times.keeps the paint from bleeding under the tape resulting in a super clean line. wont help you with keeping the line straight though.
Mike |
| Super taper or Banjo? | steve336 | Drywall | 24 | 03-27-2009 01:25 AM |
| Bonding Plastic Water/Gas Lines? | jevorik | Electrical | 3 | 12-29-2006 12:24 AM |
| Straight Horizontal Line | Speer007 | Carpentry | 17 | 12-15-2006 06:26 PM |
| Water lines | rino1494 | Excavation & Site Work | 6 | 05-06-2006 02:09 PM |
| Quickbooks - Accounts and Tax Lines | Tileworks | Technology | 2 | 01-15-2006 04:26 PM |
