Galvanized
Old 04-13-2007, 07:27 PM   #1
Tad's Avatar
Trade: Painting Contractor
Galvanized
Does anyone have suggestions on how to paint galvanized steel. The paint on it is flaking off really bad. I know you cant use oil and you have to clean it. But what kind of paint. DTM?
Tad is offline
Old 04-13-2007, 07:51 PM   #2
farrellpainting's Avatar
Trade: exterior painting contractor
Re: Galvanized
Use the search bar, this topic came up relatively recent.And the outcome yielded some great info!
farrellpainting is offline
Old 04-13-2007, 09:33 PM   #3
Workaholic's Avatar
Re: Galvanized
for metal i suggest using oil.
Sean
Workaholic is offline
Old 04-13-2007, 09:35 PM   #4
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Re: Galvanized
SW makes some real quality epoxy's. In my experience, these are the best option for galvanized steel, aluminum, and such. I used to paint submarines for a while and we used this exact epoxy.
here's a quick link, scroll down a bit to find them...http://www.sherwin-williams.com/pro/...erformance.jsp
good luck and whatever you do, DO NOT use oil...
Richard is offline
Old 04-13-2007, 10:05 PM   #5
Workaholic's Avatar
Re: Galvanized
Paintguy why no oil? Is it because of galvinised? All metal in general i use oil
Sean
Old 04-13-2007, 10:52 PM   #6
Richard's Avatar
Re: Galvanized
epoxy's are much more durable and are specifically formulated for this use. you must prime first, no matter what. I've had issues with oil based products on certain metals and would rather use the best product available when my name is on it is all. it's one thing to use a product for "metal" and another for "galvanized steel". there are a number of specific products for galvanized metal from all the top brands(SW, BM, PPG)
Richard is offline
Old 04-13-2007, 11:37 PM   #7
Joewho's Avatar
Trade: Painter
Re: Galvanized
http://www.galvanizeit.org/showContent,291,335.cfm
Joewho is offline
Old 04-13-2007, 11:59 PM   #8
lmcgrew79's Avatar
Trade: Painter
Send a message via AIM to lmcgrew79 Send a message via Yahoo to lmcgrew79
Re: Galvanized
Galvanized metal will react with oil based paints and fall of shortly there after. DTM will work. Paint will adhear better to the galvanized if you wipe it with vinegar. We also wipe it with either laquer thinner or deglosser.
lmcgrew79 is offline
Old 04-14-2007, 12:16 AM   #9
Woz the Painter's Avatar
Re: Galvanized
Years ago Im talking 20 plus, PPG used to have a product called Poly-Clutch which was recomended for all galvanized metal, it came in a 5 that was filled about 4 gals. worth, then their was a plastic 1/2 gallon bottle that you would mix in which was some kind of acid, it smelled worst than an epoxy ever, the final mix looked liked a pissed down light green paint, this contractor swore by this for galvanized, interior or exterior, and would not warantee ajob on galvanized without it...
Woz the Painter is offline
Old 04-14-2007, 06:05 PM   #10
Workaholic's Avatar
Re: Galvanized
I know it was not my thread but i learned about galvinised metal. Well thanks for the info guys, joewho's link was galvinised 101.
Sean
Galvanized gutters BMAN Painting & Finish Work 7 05-28-2007 12:06 AM
galvanized roof edging Robert S Painting & Finish Work 5 03-21-2007 10:16 PM
Help, Galvanized Pipe Break wyomble Plumbing 3 10-28-2006 07:03 PM
Replacing galvanized.........YEAH BABY toddgotfish Plumbing 6 01-02-2006 02:25 AM
how do you know if steel has been galvanized? Zeebo Painting & Finish Work 11 08-30-2005 07:33 PM
