Frozen Primer
Old 01-27-2010, 11:04 PM   #1
mics_54's Avatar
Trade: contractor
Frozen Primer
Client left 10 gallons of interior valspar primer in his vehicle last night..it was 2 degrees this am. It wasn't frozen solid but a little stiff around the edges. If it looks ok after it's mixed will it be ok? He almost cussed
mics_54 is offline
Old 01-28-2010, 01:50 AM   #2
God is Good
DiversePainting's Avatar
Re: Frozen Primer
I would normally say no because freezing forces the liquids in the paint to separate from the solids and the two properties won't be able to re-emulsify, but you said it didn't freeze completely so you should be OK. Thaw it out completely (sit it in a tub of hot water), then stir it extremely well and test it.
DiversePainting is offline
The Following User Says Thank You to DiversePainting For This Useful Post:
mics_54 (01-28-2010)
Old 01-28-2010, 05:45 AM   #3
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Re: Frozen Primer
Being that is was valspar primer that would be reason enough to pitch it.
chris n is offline
Old 01-28-2010, 09:35 AM   #4
God is Good
Re: Frozen Primer
Lmao, at Chris. you know I wonder why us painter's give big/box store a hard time. I've used Valspar several times and its not a bad product, it might be a lil pricey but still.
Old 01-28-2010, 08:51 PM   #5
alanbj's Avatar
Trade: painting
Re: Frozen Primer
valspar is very good paint. use to be top of the line back in the day.
used their exterior stain this summer and it blew my socks off,thick as a brick and flowed real nice.
alanbj is offline
Old 01-28-2010, 10:09 PM   #6
Painterboy's Avatar
Trade: Paint and Wallpaper
Re: Frozen Primer
I agree with Chris
Painterboy is offline
The Following User Says Thank You to Painterboy For This Useful Post:
chris n (01-29-2010)
Old 01-29-2010, 06:08 AM   #7
chris n's Avatar
Re: Frozen Primer
nuff said
chris n is offline
Old 01-30-2010, 07:03 AM   #8
coatingsguy's Avatar
Trade: Coatings Sales/Service & Media Blasting
Re: Frozen Primer
most acrylic / latex products, regardless of the manufacture have 1-3 freeze/thaw cycles. It needs to be stored in a nominal temp room of 70 for a minimum of 48 hours, then should be good to go. all manufactures add a certain amount of gylcol to thier products to retard freezing. Think about it. How does it get from the factory to the store? not in a heated truck. Whens the last time you bought a gallon of paint right off the back of the truck? hope that helps.
coatingsguy is offline
Old 01-30-2010, 07:57 AM   #9
ContrBob's Avatar
Trade: general contractor
Re: Frozen Primer
I wouldn't use it. Freezing separates components and changes the chemical structure.
It'll be too much work taking it off when it fails.
ContrBob is offline
Old 01-30-2010, 06:35 PM   #10
Knowledgeable Tinter!
Faron79's Avatar
Trade: Painting/Hardware Retail
Re: Frozen Primer
After thawing for a day or 2, stir thoroughly.
* If it's nice and creamy, it's good to go.
* If bottom & sides are "cottage-cheesy"...TOSS IT.
Way up here in Fargo, ND...we have to watch for this closely.
Our RL paints can be sent on heated trailers from OH once a week, if need-be.
(I've had to refuse pallet-loads b4...)
Many paints actually CAN'T take a freeze. Check the cans. ACE paints state right on the case..."Freezing makes product unsuitable for use".
SOME light crystalization is fine for many paints.
BUT...when it starts stiffening-up enough, it's history.
Faron
Faron79 is offline
B I N primer delamb harness Painting & Finish Work 17 11-04-2011 08:25 PM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 08:39 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 06:39 AM
Primer questions rebar17 Painting & Finish Work 14 10-25-2007 09:51 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 05:35 PM
