French Door Paint And Stain
Old 02-20-2006, 11:24 PM   #1
Walsh Construction Svcs.
Luke's Dad's Avatar
Question
I'm getting ready to finish a beautiful set of interior french doors with sidelights and transom. The total unit is approx. 9' high by 10' wide. The customer wanted painted jambs and dividers between the sidelights and transom and stain on the doors, sidelights and transom.
My question is which should I do first? Stain and seal the doors, sidelights and transom, or paint the jambs and dividers first.
Any suggestions would be appreciated!
Thanx!
Lance
Luke's Dad is offline
Old 02-21-2006, 12:23 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: French Door Paint And Stain
The painters will be along with the right answer. For me in the past I liked the benefits of staining and sealing first then painting, being that the wood was prepred already and didn't have to worry about hurting delicate painted areas in preping the wood for stain, plus once stained and sealed any paint that got over shot would wipe right off.
Mike Finley is offline
Old 02-21-2006, 09:32 AM   #3
Painting Contractor
JMGP's Avatar
I would stain first.. then paint...
Stain first becuase it's messy and if you get stain on the part that is getting paint ... no worries.. its getting painted...
Apply first coat of sealer over stain before paint... if you get a little paint on the edge where the stain is.. it will wipe off easier....
Joe
JMGP is offline
Old 02-21-2006, 11:46 PM   #4
ROG OF DCA CUSTOM PAINTIN
DCA1GR8P8R's Avatar
Trade: PAINTER
Send a message via Yahoo to DCA1GR8P8R
Talking
Definately Stain First....
Cause Any Laps Of Stain Is Not Gonna Effect The Out Come Of The Painted Wood Work.....and The Stained Will Be Sealed And Finished So As If Any...i Am Not Making Any Observations... Slips Or Paint Is On The Stained It Wont Have Any Effect And Will Clean Up Easy And Dont Have To Worry About Sanding Off The Paint Or Primer....
DCA1GR8P8R is offline
Old 02-23-2006, 09:36 AM   #5
johnthepainter
johnthepainter's Avatar
Trade: painting contractor
stain first,,,,,,,
johnthepainter is offline
Old 02-23-2006, 09:55 AM   #6
SAGE
sage's Avatar
Trade: Remodeler and Finish Carpenter
Or you could Paint, then stain. Then fix the painted areas that you got the stain on then paint again. Seemed to make sense to one of the pin heads I had on my crew in the past.
-Lead from the front, or dont lead at all-
sage is offline
Old 02-23-2006, 09:57 AM   #7
Chief Toilet Mover
I like that. But take it easy on them, at least they stop after one complete go around in the circle, it could be worse and they could still be there sanding off the paint that got on the stain and restaining, then repainting where they just got the stain back on the paint, then fixing where they just got paint back on the stain, then....
Best opaque stain product??? Barbara Masonry Picture Post 2 07-11-2007 07:18 PM
Pricing stain work airborneSGT Painting & Finish Work 3 03-27-2007 08:36 PM
Stain b/4 or after installation??? pitterpat Painting & Finish Work 10 10-09-2006 07:15 AM
Stain trim b/4 or after installation pitterpat Carpentry 3 10-08-2006 11:09 PM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
