Floating Over A Wallpaper Border?
Old 08-15-2012, 06:21 PM   #1
ruissar's Avatar
Trade: home repair
Rewards Points: 18
I have a large bathroom that is wall papered and on top of the wallpaper there is a border. They want to paint the bathroom, would it be logical to use mud to float over the top and bottom of the border, and paint over wallpaper?
ruissar is offline
Old 08-15-2012, 06:26 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,168
Re: Floating Over A Wallpaper Border?
remove the wall paper and border, then paint.
sunkist is offline
Old 08-15-2012, 06:34 PM   #3
ExtremePride's Avatar
Trade: general contractor
Rewards Points: 85
I have seen guys around here skim coat mud over wallpaper. Does nothing but make a big mess, bubbles everywhere. When they are done removing all the bubbles, for days on end, the wallpaper is mostly gone. Remove wallpaper and go from there.
ExtremePride is offline
Old 08-15-2012, 06:39 PM   #4
ruissar's Avatar
Trade: home repair
Rewards Points: 18
The home owner didn't want the expense of removing it, better to ask then to try something crazy! Thanks
ruissar is offline
Old 08-15-2012, 06:48 PM   #5
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,290
They must have some rocks they are trying to squeeze some water out of.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 08-15-2012, 06:52 PM   #6
schaefercs's Avatar
Rewards Points: 520
Have fun with all the bubbles you'll run into after you skim it.
schaefercs is offline
Old 08-15-2012, 07:08 PM   #7
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 502
We’ve done it several times with great success. We only do it after we’ve tried to remove the paper with no joy. If it can be removed, it is usually more economical to remove the paper than to skim coat and texture the room.
Good luck
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following 2 Users Say Thank You to DaVinciRemodel For This Useful Post:
hdavis (08-16-2012), ruissar (08-15-2012)
Old 08-16-2012, 12:57 AM   #8
HomerJ's Avatar
Trade: Remodeling Specialist - General Contractor
Rewards Points: 150
I'd rather tear out and replace the drywall than spend a second trying to remove or skim coat over paper.
HomerJ is offline
Old 08-16-2012, 09:13 PM   #9
hdavis's Avatar
Rewards Points: 4,665
Good luck
Second that. If it won't come off, you can skim. If it'll come off, you can't skim. Loose and bubbled areas have to be taken off first.
OR, if you just HAVE to do it, use an oil base primer to keep from having the wallpaper loosen, then skim
hdavis is online now
Old 08-17-2012, 06:35 AM   #10
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
It's a bathroom getting exposure to large volumes of steam, he should of just said, your'e right let's redrywall,. why give to charity when you can give to psychopathics.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 08-18-2012, 10:34 PM   #11
Miss Brown's Avatar
Trade: Wood n' concrete finishes
Rewards Points: 150
I wouldn't have done this on a job, but I did on my own house. Got off what I could, sealed with oil primer, skim-coat. It hasn't failed...yet...it will.
Miss Brown is offline
Old 08-30-2012, 02:14 AM   #12
Irish Painter's Avatar
Trade: Painting and Decorating
Remove the border at least. Prime the remaining paper on the wall. Lining paper to the walls left to right. Not up and down. Leave a 1.5mm gap between each line and when dry fill the gaps between the sheets. Seal the whole surface and gp around and silocone with a paintable type between the walls and the ceiling then paint. Job done
Irish Painter is offline
Old 08-30-2012, 10:12 AM   #13
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,079
Sir Mixalot is offline
Installing Wallpaper Murals ("digital" murals) Rowan Wallpaper 9 07-31-2012 01:32 PM
Stucco on wallpaper... The best solution for residential buildings. aulona Wallpaper 10 07-23-2012 03:30 PM
Easily removing Wallpaper !!!!!YUCK!!!!! PaintedLady Specialty Coatings 13 04-19-2011 06:32 PM
Bathroom, peeled wallpaper, need to texture n paint Red Adobe Painting & Finish Work 5 02-18-2010 07:59 PM
Choosing between floating or stapled hardwood OuchMyThumb Flooring 1 01-22-2010 01:12 PM
