Flat Vs. Eggshell
Old 04-09-2007, 07:31 AM   #1
Traditions's Avatar
Trade: painting
Flat Vs. Eggshell
what do you all use more of. I have been doing basically new construction the last few years. I always recommend an eggshell. However, most new homes I go into have flat in them. I did a huge staircase with a monster window behind it in eggshell this past week. I had a hell of a time with it. Kept seeing my marks. Would most people use a flat in this situation. I like the look of eggshell. Just seems like most contractors are putting flat in their homes to cover crap up.
Traditions is offline
Old 04-09-2007, 08:03 AM   #2
Exroadog's Avatar
Trade: paint
Re: Flat Vs. Eggshell
I'd go matte! Split it. I personelly like flat, never have liked shiney walls. Most flats are hard to clean but i've had good luck with Regal flat wall finish. I generally talk them into the Matte though. Washable yet helps in hiding the flashing of bad drywall!
Exroadog is offline
Old 04-09-2007, 08:15 AM   #3
KellyPainting's Avatar
Trade: Painting Contractor
Matte is just another name for flat... right?
like blanco is spanish for white?
Always use flat when possible, especially in new construction. The difference is that when you fix anything with mud or caulk it will flash
when painted with eggshell, unless you prime first (adding more work)
with flat you do not have to. Also when painting with eggshell you must keep a wet edge and roll each wall as it's cut in...before it dries otherwise you will have lines or marks (or flashing). Also some new self primeing products like super hide ben moore is not recomended to be top coated with any sheen level. And if not for all that.... flat can be touched up
when eggshell.. the whole wall must be painted again.
KellyPainting is offline
Old 04-09-2007, 09:04 AM   #4
Traditions's Avatar
Trade: painting
I hate long walls and windows.
Old 04-09-2007, 09:15 AM   #5
MakDeco's Avatar
Mostly re paints here and most women want eggshell. I have a disclaimer in my proposals that states, using eggshell (or shinier) paints may cause imperfections that weren't previously noticed to become visible (most builders flat hides bad taping on large walls) and I am not responsible for them. I can charge to fix them, charge them to repaint in flat etc...
I try talking them into flat or matte. Most damn interior decorators that I have worked with on jobs even architects spec eggshell or even pearl! Please stop doing that ! (just tell people to control there kids and not touch the damn walls all the time.)
Also the eggshell I use from P&L says aqua matte on it (red Seal) it is not as shiny as BM's velvet and some others out there.
MAK Deco
MakDeco is offline
Old 04-09-2007, 09:27 AM   #6
Traditions's Avatar
Trade: painting
I've used duration home matte finish. It looks as shiny as eggshell to me. I was thinking about doing walls in eggshell except stairways, long walls with windows, etc.
Old 04-09-2007, 09:27 AM   #7
Exroadog's Avatar
Trade: paint
[QUOTE=KellyPainting;224005]Matte is just another name for flat... right?
Nope. Its in between flat and egg.
Exroadog is offline
Old 04-09-2007, 09:29 AM   #8
...jammin
slickshift's Avatar
Trade: Rock Disciple
The past few years it's been a trend toward eggshell
I'd say it's at the point now where I paint more walls eggshell then flat
I'm sure most builders prefer and use flat
But with re-paints, I do what the customer wants
Signature Quote
slickshift is offline
Old 04-09-2007, 12:28 PM   #9
aspenpainting's Avatar
Trade: int/ext painting
Flat on new construction and it eggshell on interior repaints for me. Seems homeowners always go for the eggshell im going to try to push for more flat though.
aspenpainting is offline
Old 04-09-2007, 12:36 PM   #10
Traditions's Avatar
Trade: painting
with scrubbable flats it should be easier to convince. I would rather have flat in my own house. If i scuff the wall with eggshell I have to reroll the whole wall. If i scuff flat I can simply touch it up. Paint with more sheen isn;t exactly scrubbable in my opinion. Sometimes when you try to scrub a eggshell, satin, or semi, it leaves a smudge. With flat it usually dries flat or you can just touch it up.
Old 04-09-2007, 04:35 PM   #11
DeanV's Avatar
Trade: Painter
In my area, the trend is definitely the washable flats/matte.
DeanV is offline
Old 04-09-2007, 07:02 PM   #12
Workaholic's Avatar
I mostly do flats, I am doing a touch up right now, should be out tomorrow. the house is 7000 sqft all eggshell except closets.
Sean
Workaholic is offline
Old 04-09-2007, 07:11 PM   #13
George Z's Avatar
From the bilingual Canada:
"Matte" is French for flat.
Kelly is right.
On our labels it says Flat on one side,
Matte on the other.
The word can take a meaning of it's own, like calling sponging "faux"
But really, Matte means flat.
We use about 50% washable flats, the rest Eggshell or Pearl
George Z is offline
Old 04-09-2007, 07:21 PM   #14
Exroadog's Avatar
Trade: paint
I'm sure you are right George. But BM Matte painted next to flat has a slight sheen compared to the flat. If its got a sheen....it aint flat..IMO.
I remember being up in Cold Lake Alberta for a month and the first time I went grocery shopping I was pissed cause I couldnt read the labels. Then I realized you just turn the can around and its written in English.
Exroadog is offline
Old 04-09-2007, 07:29 PM   #15
Art Home Painting
amauri's Avatar
The flat finish is nicer anyway.When the my costumers of repaintings see the result she/he is always happier than when we use egg****.
AMAURI
amauri is offline
Old 04-09-2007, 07:39 PM   #16
Ya, your right.... at ben moore there is flat and matte
but some other paints there is only flat matte..like behr for instance.
Old 04-09-2007, 07:43 PM   #17
George Z's Avatar
I had an older Scottish Painter working for me years ago.
He only poured the paint and wiped his brush on the French side of the can.
George Z is offline
Old 04-09-2007, 07:54 PM   #18
MakDeco's Avatar
Ralph Lauren's matte is there flat also and let me tell ya I saw it once on a wall and its shiny like eggshell so IMO RL doesn't make a flat!
MAK Deco
MakDeco is offline
Old 04-09-2007, 09:30 PM   #19
nick@nite
THINKPAINTING's Avatar
Ever try and wash the so called washable paints .....remember Ever Clean from SW.....Now its Ben Moore Matte finish for 30 dollars a gallon
Pro Mar 200 or Super Spec from ben moore cover just as well and wash as well.
Super Spec Egg from Ben Moore is a nice product. I will take flat in hallways anyday......baths and kitchens egg......
THINKPAINTING is offline
Old 04-09-2007, 09:56 PM   #20
boman47k's Avatar
I think Lowe's has matte beteen flat and eggshell in the sample display on the paint counter. Just an observation.
boman47k is offline
What was wrong with flat extension cords?? K2 Health & Safety 13 03-19-2007 12:19 PM
scrubbable flat Traditions Painting & Finish Work 9 02-08-2007 01:14 AM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
FYI, Velux for flat roofs Grumpy Roofing 7 12-05-2005 11:01 AM
