Which Flat Paint From Sherwin Williams In A Million Dollar Home 3,300 Sq Ft
Old 05-10-2017, 11:25 PM   #41
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Re: Which Flat Paint From Sherwin Williams In A Million Dollar Home 3,300 Sq Ft
Is it true CHB stands for Chicago home builders? My rep was telling me a story about how it was specifically formulated for a massive HUD project and it sold so well, they kept selling it. Said it's sole purpose was to Hide, but not do much else.
It sure does the hiding part quite well.
Some of the stories reps tell you, you gotta have a hard time believing.
www.callbathdoctor.com
Driftweed is offline
Old 05-11-2017, 04:28 AM   #42
John1957's Avatar
Trade: Home Improvement
Rewards Points: 212
Originally Posted by avenge View Post
I haven't used Cashmere in years so I have no idea if the formulation has changed today's low or no voc paints dry faster. A 2-1/2 inch angle is too small to be cutting in walls,. Always cut in the walls and allow it to dry before rolling.
Yeah Yeah Yeah.... My son busts on me about the 2 1/2" all the time.
I have tried 3" & 4" brushes many times, and they are a bit faster, but I love how my 2 1/2 Wooster feels, and the control I have with it.
John1957 is offline
Old 05-11-2017, 10:16 AM   #43
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,646
I love my 3" Straight Wooster for cutting. It gives you the same stroke pushing or pulling.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
The Following User Says Thank You to TNTSERVICES For This Useful Post:
John1957 (05-11-2017)
Old 05-12-2017, 07:14 PM   #44
NucaveConst.'s Avatar
Rewards Points: 8
I would use SuperPaint or Emerald. Haven't used Cashmere.
Spray and back-roll. If it needs 2 coats, you can just back-roll the 2nd coat. It covers great. I'm sure Cashmere will be fine.
____________________
3 Ways To Add Years To Your Wood Fence
NucaveConst. is offline
Old 05-12-2017, 07:21 PM   #45
Rewards Points: 8
Now why do you let it dry?
I paint it while it's wet so it blends better and there's no flashing.
Old 05-12-2017, 08:26 PM   #46
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 482
The unspoken rule of painting is to always try and keep a wet edge. If you let your edging dry, then, rolling over that area will put on 2 coats in areas where the roller goes onto the dried edging.
Caslon is offline
Old 05-12-2017, 08:29 PM   #47
Rewards Points: 8
Exactly
Nucave Construction Blog
Old 05-12-2017, 08:42 PM   #48
avenge's Avatar
Rewards Points: 2,790
If you cut in a room or even one wall the cut in is already tacking up by the time you start rolling. That's the last thing you want and will look exceptionally bad. The unspoken rule applies while brushing or rolling keep a wet edge not between the rolling and cutting. I don't have issues with flashing between cutting and rolling the worst problems I've had with flashing is when the drywall hasn't been sealed.
avenge is online now
Old 05-13-2017, 12:07 AM   #49
Caslon's Avatar
Rewards Points: 482
Keeping a wet edge when rolling paint across walls isn't that hard. Edge the top and bottom 6' ahead of you. Maintaining a wet film has it's real advantages over letting the edging dry.
I think we've wandered off the OP's topic.
Caslon is offline
Old 05-13-2017, 01:07 AM   #50
avenge's Avatar
That's probably one of the dumbest methods I've ever heard suggested.
Old 05-13-2017, 01:49 AM   #51
Caslon's Avatar
Rewards Points: 482
You do painting exclusively? Who are you speaking for? Remodlers like yourself and such, or, day in and day out painting contractors?
Can we make this last, or will it just be over?
Caslon is offline
Old 05-13-2017, 10:45 AM   #52
Rewards Points: 8
Seriously this needs to be put to bed.
Cut ahead of yourself as far as you can, but don't let the cut-in dry before you come back and roll. it's that simple. Can you get away with letting it dry? sure. but this is the best practice.
Old 05-13-2017, 11:07 AM   #53
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,140
You need a heaping helping of tact.
Sent from my SM-N910T using Tapatalk
sparehair is offline
Old 05-13-2017, 11:41 AM   #54
Caslon's Avatar
Rewards Points: 482
shhhh. Painting contractor forum.
Caslon is offline
Old 05-13-2017, 12:15 PM   #55
avenge's Avatar
I've been doing this for 43 years, full time painter for 25. I now do mostly remodeling. Casion we know you don't understand what remodeling is, you can't even spell it correctly.
You don't need to be a full time painter to know something about painting. If I saw anyone on my job cutting in 6ft, grabbing a roller, rolling 6ft over and over again you'd be fired.
And if you're asking for tact from me.....good luck.
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1851 09-27-2016 11:09 PM
Building with Adobe as a Cost Effective Solution for Home Construction? tierraconcepts Green Building 14 09-19-2015 05:52 PM
Get any and all Columbia Forest Products at Home Depot if needed TBFGhost Carpentry 15 01-02-2013 08:31 PM
Best Paint for a Historic Home fatal_degree Painting & Finish Work 15 04-23-2010 08:09 AM
I find some of these names,shocking sjm Painting & Finish Work 7 08-20-2007 05:51 AM
