Fix Aligatoring
Old 05-25-2008, 05:43 PM   #1
shayter's Avatar
Trade: paint
Fix Aligatoring
need to fix aligatoring on a new build with primer on drywall, with two topcoats. The topcoat aligatored in various places. How do I go about doing this without hurting the primer coat?
shayter is offline
Old 05-25-2008, 09:21 PM   #2
Hudson Valley
mjay's Avatar
Trade: Restorative Painting
Re: Fix Aligatoring
Determine cause: oil? wax? incompatible paints? old paint? substrate wet? paint thinned too much? contaminated paint? Best to avoid repeating this error!
I'd try an oil based primer, followed by skim coat of suitable mud, apply quality latex primer and finish paint.
Good luck, take pics and keep us informed.
www.blueskiesrestorations.com
There's some top class people on this forum,........and then there's me...Touching cloth.
mjay is offline
Old 05-25-2008, 11:21 PM   #3
shayter's Avatar
Trade: paint
Re: Fix Aligatoring
how do you determine weather the primer coat, and top coat were incompatible causing the aligatoring, or if it was something else?
shayter is offline
Old 05-26-2008, 01:23 PM   #4
TooledUp's Avatar
Trade: Decorator and Taper
Re: Fix Aligatoring
I would telll the HO to get the 'professional' guy who did it to repair it http://www.contractortalk.com/f8/help-paint-problems-39799/
If the primer was a fire retardant then it's going to seal the board pretty well - The finish coats would probably need a lot longer to dry between coats than the guy allowed... Possibly overnight.
Handle every stressful situation like a dog.
If you can't eat it or hump it...
P*ss on it and walk away.
TooledUp is offline
Old 05-26-2008, 07:40 PM   #5
capital city's Avatar
Trade: painting
Re: Fix Aligatoring
It might just need sanded, alot of drywallers will go a little excessive in spots and bur up the paper part around the mud. Good Luck
capital city is offline
Old 05-27-2008, 07:41 AM   #6
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Fix Aligatoring
Doesn't matter about "hurting" the primer coat
You're gonna want to prime again anyway
Sand, sand, sand....if you go into the primer, so be it
Re-prime
Paint
Depending on why it's alligatored, you might want to use a special or specific primer
I'd want to figure out why it alligatored
Signature Quote
slickshift is offline
Old 05-27-2008, 09:53 AM   #7
Hudson Valley
mjay's Avatar
Re: Fix Aligatoring
If the alligatoring is sporadic, isolated, then more likely not allowing primer to dry, wet on wet finish coats, oil/wax, etc.
You want to experiment, repeat the process and eliminate each possible cause.
mjay is offline
Old 05-27-2008, 06:14 PM   #8
shayter's Avatar
Trade: paint
Re: Fix Aligatoring
it cracked sporadicaly, but the primer was no wet. It had several days to dry.
shayter is offline
